I accidentally uninstalled certbot and certificates
My domain is: www.wirpool.ddns.net
I ran this command: » sudo certbot --nginx -d wirpool.ddns.net -d www.wirpool.ddns.net
Requesting a certificate for wirpool.ddns.net and www.wirpool.ddns.net
http-01 challenge for www.wirpool.ddns.net
Challenge failed for domain www.wirpool.ddns.net
    Domain: www.wirpool.ddns.net
    Type: dns
    Detail: DNS problem: NXDOMAIN looking up A for www.wirpool.ddns.net
    • check that a DNS record exists for this domain; DNS problem:
      NXDOMAIN looking up AAAA for www.wirpool.ddns.net - check that a
My web server is (include version): nginx/1.18.0
The operating system my web server runs on is (include version): Raspbian GNU/Linux 11 (bullseye)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.12.0
I used apache as webserver, when I uninstalled apache and installed nginx it had some problems and probably trying to fix them I deleted all certbot and certficates. Now trying to request for another one it answer what you can see up.
This means there is no www.wirpool.ddns.net domain -- which is different from wirpool.ddns.net.
You should just remove that domain from your command, or configure its dns so that it points the right way (but... can you do that, on ddns.net?)
Good, it was easier than what what I tought. I just raa this command and all done.
Thankyou very much.
