https://www.phtvs.nl/index.php/raspberry-pi-ssl-certificaat-let-s-encrypt-in-nginx
I have done everything
But this i become for error
3: CryptographyDeprecationWarning: OpenSSL version 1.0.1 is no longer supported by the OpenSSL project, please upgrade.
how must i that upgrade???
Hi @fransko
perhaps try to update your certbot.
What says
sudo apt update
sudo apt upgrade
Osiris
#3
I think updating OpenSSL from 1.0.1 to 1.0.2 is more helpful.
i have done that but it doesn’t work how can i cerbot update?
Osiris
#5
What is the output of apt -s install openssl
What is the certbot command line and it output?
pi @ raspberrypi: / etc / nginx / sites-available $ sudo apt -s install openssl
Package lists are read … Ready
Tree of requirements is being built
The status information is read … Ready
openssl is already the newest version.
openssl is set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 14 not upgraded.
Sender notified by
[Mailtrack](https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&)
28-04-19 21:01:56
do you have google hangout??
Sender notified by
28-04-19 21:14:19
system
closed
#8
