Https certificate not generating for Namecheap domain
Domain is: x
Web server is: Nginx (latest, 1.19.3)
Hosting provider is: Vultr private VPS
Operating system of VPS is: Ubuntu 18.04 x64
Can login to a root shell on my machine: yes
Have a handful of Google domains and have had no issues with getting Let's Encrypt to generate certificates using the same shared nginx-proxy and letsencrypt-nginx-proxy-companion setup. Therefore I am assuming, for now at least, this is an issue with how I have the domain configured through Namecheap.
caa
Seeking assistance on how to further triage the issue I'm encountering, having exhausted my limited knowledge and searching through these forums and others.
Are there error messages (or any messages in general, really) from letsencrypt-nginx-proxy-companion?
Your DNS setup looks just fine, so the detail of what's going wrong is needed to help you.
Turns out digging in for better context quickly led me down the right path; it was due to "ACME server returned an error: urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Error creating new authz :: Validations for new domains are disabled in the V1 API (End of Life Plan for ACMEv1)". Adding a patch for letsencrypt-nginx-proxy-companion did the trick. :sweat_smile:
