My domain is: mehome.com.au
I ran this command: I followed all instruction here. https://certbot.eff.org/lets-encrypt/centosrhel7-nginx
My web server is (include version):nginx
The operating system my web server runs on is (include version):centos7
My hosting provider, if applicable, is: vultr.com
I can login to a root shell on my machine (yes or no, or I donât know): yes
Iâm using a control panel to manage my site (no, or provide the name and version of the control panel): I use putty and panel bt(chinese version)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if youâre using Certbot):
File â/usr/bin/certbotâ, line 5, in
from pkg_resources import load_entry_point
File â/usr/lib/python2.7/site-packages/pkg_resources/init.pyâ, line 3250, in
@_call_aside
File â/usr/lib/python2.7/site-packages/pkg_resources/init.pyâ, line 3234, in _call_aside
f(*args, **kwargs)
File â/usr/lib/python2.7/site-packages/pkg_resources/init.pyâ, line 3263, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File â/usr/lib/python2.7/site-packages/pkg_resources/init.pyâ, line 585, in _build_master
return cls._build_from_requirements(requires)
File â/usr/lib/python2.7/site-packages/pkg_resources/init.pyâ, line 598, in _build_from_requirements
dists = ws.resolve(reqs, Environment())
File â/usr/lib/python2.7/site-packages/pkg_resources/init.pyâ, line 791, in resolve
raise VersionConflict(dist, req).with_context(dependent_req)
pkg_resources.ContextualVersionConflict: (cryptography 2.1 (/usr/lib64/python2.7/site-packages), Requirement.parse(âcryptography>=2.3â), set([âPyOpenSSLâ]))
