How to use certbot with <VirtualHost *:8080>
My domain is: blog.ondata.it
It produced this output: Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80
My web server is (include version): Apache/2.4.25 (Debian)
The operating system my web server runs on is (include version): Debian 9
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): webmin 1.983
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.28.0
Hy,
this is a part of my apache config
SuexecUserGroup "#1000" "#1000"
ServerName wp.ondata.it
# Server aliases for wordpress multisite domain mapping
ServerAlias blog.ondata.it
I would like to use certbot for my ServerAlias site, blog.ondata.it. It's a site inside wordpress multisite.
How to use certbot client to do it?
Thank you
Hi @aborruso and welcome to the LE community forum :slight_smile:
Even though you have root access (and could do much of this manually), I see that you are using webmin, and as such, I would recommend looking within that program/menus for a way to enable SSL on your site first.
If webmin is not capable of handling the SSL, then we would have to begin at the beginning...
  • Have you ever created a HTTPS (secure) site?
  • How comfortable are you with creating HTTP (insecure) sites?
Hi @rg305 I did it using simply certbot client in a webserver that had a separate configuration file for each site and all on port 80.
Here I have a wordpress multisite config file, the 8080 port, and I want to set a SSL for one of the subsite of multisite. Where could i start, without using webmin?
Sorry, I don't know how to enable SSL on WordPress sites.
Without WP, you should be able to run certbot to make secure sites from the HTTP sites found.
Unfortunately, certbot is unable to locate any HTTP sites.
Let's try locating them with:
sudo apachectl -t -D DUMP_VHOSTS
I have this (it's the part related to blog.ondata.it)
VirtualHost configuration:
*:8080                 is a NameVirtualHost
         default server ondata.it (/etc/apache2/sites-enabled/000-default.conf:1)
         port 8080 namevhost wp.ondata.it (/etc/apache2/sites-enabled/wp.ondata.it.conf:1)
                 alias blog.ondata.it
                 alias ....
So that is the only related vhost?
If so, please show the file:
It's this (thank you)
ServerAlias anothere1.ondata.it
ServerAlias anothere2.ondata.it
DocumentRoot /home/ondata/domains/wp.ondata.it/public_html
ErrorLog /var/log/virtualmin/wp.ondata.it_error_log
CustomLog /var/log/virtualmin/wp.ondata.it_access_log combined
ScriptAlias /cgi-bin/ /home/ondata/domains/wp.ondata.it/cgi-bin/
DirectoryIndex index.html index.htm index.php index.php4 index.php5
<Directory /home/ondata/domains/wp.ondata.it/public_html>
Options -Indexes +IncludesNOEXEC +SymLinksIfOwnerMatch +ExecCGI
allow from all
AllowOverride All Options=ExecCGI,Includes,IncludesNOEXEC,Indexes,MultiViews,SymLinksIfOwnerMatch
Require all granted
AddType application/x-httpd-php .php
AddHandler fcgid-script .php
AddHandler fcgid-script .php5
AddHandler fcgid-script .php7.0
FCGIWrapper /home/ondata/domains/wp.ondata.it/fcgi-bin/php7.0.fcgi .php
#FCGIWrapper /home/ondata/domains/wp.ondata.it/fcgi-bin/php5.fcgi .php
FCGIWrapper /home/ondata/domains/wp.ondata.it/fcgi-bin/php5.fcgi .php5
FCGIWrapper /home/ondata/domains/wp.ondata.it/fcgi-bin/php7.0.fcgi .php7.0
</Directory>
<Directory /home/ondata/domains/wp.ondata.it/cgi-bin>
allow from all
Require all granted
</Directory>
RewriteEngine on
RewriteCond %{HTTP_HOST} =webmail.wp.ondata.it
RewriteRule ^(.*) https://wp.ondata.it:20000/ [R]
RewriteCond %{HTTP_HOST} =admin.wp.ondata.it
RewriteRule ^(.*) https://wp.ondata.it:48121/ [R]
RemoveHandler .php
RemoveHandler .php5
RemoveHandler .php7.0
php_admin_value engine Off
IPCCommTimeout 31
FcgidMaxRequestLen 1073741824
</VirtualHost>
<VirtualHost *:443>
allow from all
Require all granted
#FCGIWrapper /home/ondata/domains/wp.ondata.it/fcgi-bin/php7.0.fcgi .php
</Directory>
allow from all
Require all granted
</Directory>
RewriteEngine on
RemoveHandler .php
RemoveHandler .php5
IPCCommTimeout 31
SSLEngine on
SSLCertificateFile /home/ondata/domains/wp.ondata.it/ssl.cert
SSLCertificateKeyFile /home/ondata/domains/wp.ondata.it/ssl.key
SSLProtocol all -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
</VirtualHost>
That file seems a bit altered.
WP has issued a cert within it - but only for one name.
All the ServerAlias exists only in the insecure vhost.
Did WP put those aliases in there?
[or did you edit the file and add them manually]
This it the raw one
ServerAlias www.wp.ondata.it
ServerAlias webmail.wp.ondata.it
ServerAlias admin.wp.ondata.it
ServerAlias premio.ondata.it
ServerAlias opendatasicilia.it *.opendatasicilia.it # Own virtual host
ServerAlias opendatacampania.it *.opendatacampania.it
ServerAlias opendataemiliaromagna.it *.opendataemiliaromagna.it
#ServerAlias ricostruzionetrasparente.it www.ricostruzionetrasparente.it
allow from all
Require all granted
</Directory>
allow from all
Require all granted
</Directory>
RewriteEngine on
RemoveHandler .php
RemoveHandler .php5
IPCCommTimeout 31
</VirtualHost>
<VirtualHost *:443>
allow from all
Require all granted
</Directory>
allow from all
Require all granted
</Directory>
RewriteEngine on
RemoveHandler .php
RemoveHandler .php5
IPCCommTimeout 31
SSLEngine on
</VirtualHost>
OK
But were those aliases added in manually or by WordPress?
I think manually, but I'm not sure
It makes a difference because WP is involved.
Let's get you a cert and you can deal with any possible WP problem when/if that happens (later).
First:
Let's test that challenge file location, with:
[placing a test file in the expected challenge location and verify that it can be reached from the Internet]
echo "TestFile1" > /home/ondata/domains/wp.ondata.it/public_html/Test_File-1
yes it is http://wp.ondata.it/Test_File-1
OK.
Now to get you a cert.
Do you only need that one name?
[ blog.ondata.it ]
If so, try:
certbot certonly -d blog.ondata.it --http-01-port 8080
You are very very kind, thank you very much.
Now I have
   /etc/letsencrypt/live/blog.ondata.it/fullchain.pem
Now, what do I must change to have this site in https? Do I must change /etc/apache2/sites-enabled/wp.ondata.it.conf?
I would create a separate file - to avoid having it overwritten by WordPress.
Create a new file in that folder but call it: blog.ondata.it.conf
It should look a lot like the secure portion (bottom half of the) wp.ondata.it.conf file.
Post your edited file here to confirm it.
Can I simply copy the my wp.ondata.it.conf file and edit it in this way, and save it as blog.ondata.it.conf in that folder?
That's not enough of an edit.
You only need from line 53+
And a lot within that is specifically for wp.ondata.it, so I doubt you will need those lines either.
Also, is the "blog" site going to be just an alias to the "wp" site?
