How to setup nginx, certbot/dns-cloudflare using docker-compose?
Hi everyone. Now, I am trying to setup the nginx web sever with certbot using dns-cloudflare plugin. Is there anyone who can help me how to setup the flow including enroll and renewal of certificates using cron job together with docker-compose setup?
My domain is: example.testlab.com, www.example.testlab.com,
certbot certonly
--dns-cloudflare
--dns-cloudflare-credentials ~/.secrets/certbot/cloudflare.ini
--dns-cloudflare-propagation-seconds 60
-d example.testlab.com, www.example.testlab.com
It produced this output: I can successfully enroll the certificates, But when I setup the nginx, I faced 520 error but my backend application is running in the background using pm2.
My web server is (include version): nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version): Linux
My hosting provider, if applicable, is: Namecheap with cloudflare setup
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.21.0
Thank you for assisting us in helping YOU!
Hello @MrPhyaeSoneThwim, welcome to the Let's Encrypt community. :slightly_smiling_face:
You might find nginx documentation and https://forum.nginx.org/ helpful as well.
And the nginx plugin:
https://eff-certbot.readthedocs.io/en/stable/using.html#nginx
And the Cloudflare DNS plugin:
https://certbot-dns-cloudflare.readthedocs.io/en/stable/
Can you give me the precise solution for that? Otherwise, Would you rather suggest me to ask in nginx forum?
Kindly wait to see if there are more knowledgeable Let's Encrypt community volunteers willing to assist.
It doesn't sound like the certificate is responsible for this. Usually 520 errors are from something else. As you're using certbot with the certonly subcommand, you've installed the certificate manually, so it's also not a nginx configuration problem caused by Certbot.
Maybe visit:
