My domain is: *.shyamjos.com
I ran this command ./certbot-auto certonly --manual -d *.example.com -d example.com --agree-tos --manual-public-ip-logging-ok --preferred-challenges dns-01 --server https://acme-v02.api.letsencrypt.org/directory to setup lets encrypt wildcard cert.
Now, How can I automate the renewal process?
My web server is nginx and i am using route53 for dns management
when I am running ./certbot-auto --dry-run renew I am getting below error.
Processing /etc/letsencrypt/renewal/shyamjos.com.conf
Could not choose appropriate plugin: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.',)
Attempting to renew cert (shyamjos.com) from /etc/letsencrypt/renewal/shyamjos.com.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.',). Skipping.
/etc/letsencrypt/live/shyamjos.com/fullchain.pem (failure)
