How to renew certificate with --manual --preferred-challenges dns certonly
lccdo.edu.ph
sudo certbot -d dd.sub.domain --manual --preferred-challenges dns certonly
My web server is (include version): apache
The operating system my web server runs on is (include version): ubuntu 16.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.26.1
how can i renew my certificate? this is an intranet site only. i used the “sudo certbot -d dd.sub.domain --manual --preferred-challenges dns certonly”
--manual without scripts to automate the DNS update isn’t a workflow that supports renew.
To renew, you just repeat the process (run certonly again).
so i will just issue "sudo certbot -d dd.sub.domain --manual --preferred-challenges dns certonly"
Yes.
Since you use Cloudflare for your domain, you might also be interested in https://certbot-dns-cloudflare.readthedocs.io , which would make your renewal totally automatic.
thanks…i will try it…
