I haven't seen that Certbot can do DNS challenge. Well that simplifies my situation I believe. I will try it right now and come back with a response!
It depends on how you installed Certbot, which version you have, and which DNS provider you use.
...or there are plenty of other clients that do; one of the more popular seems to be acme.sh.
Are you guys still on track to release ACMEv2, wildcard, and a compatible Certbot by February 27?
Also, will the format of the command line and the manually generated CSRs I use (with the exception of allowing wildcards) still be the same?
Are wildcard certs available now, since yesterday was February 27th? Where can the details/documentation for that be found?
@GiantNinja, It's been delayed.
See here:
Agreed⦠Quality is definitely more important here than making an arbitrary deadline. I just didnāt see any update on that, so I appreciate the reply. Keep up the great work!
Wildcard support is available since March of 2018. Please see this post for details: ACME v2 and Wildcard Certificate Support is Live
