My domain is: testCA.test_dummy.com
Let's Encrypt provides globally signed DV certs.
Which can be used by all types of systems/applications and are trusted worldwide.
But it seems that what you need is a locally trusted CA cert for a test/lab environment.
If so, you should start by seeking out a public CA system that best fits your needs/environment.
In order to use Let's Encrypt certificates in this scenario, each client would need to be reachable as a unique (sub)domain with public DNS records since Let's Encrypt certificates are domain-validated (DV) certificates.
