My domain is:afcdeliveryrun1.youritbase.com
or certbot-auto --version
if you're using Certbot):
My web app host on other server https://afcdeliveryrun.appgyverapp.com which I don't have DNS control on it.
I would like to use my own domain: afcdeliveryrun1.youritbase.com.
I have created a cname record
afcdeliveryrun1.youritbase.com CNAME afcdeliveryrun.appgyverapp.com
Questions:
- Can I run certbot to generate the ssl cert for afcdeliveryrun1.youritbase.com
- Do I need to create a virtual host on my own server to get the ssl cert?
If so, the virtual host will point to my server ip instead of the ip address of afcdeliveryrun.appgyverapp.com. It seem not working. I am using hestiacp as the control panel.
Regards,
