Is that version of cPanel able to get certificates?
If so, you won't need another ACME client.
you are talking about installing acme client right?
In order to get a cert via ACME, you will need an ACME client.
That said, maybe cPanel has already installed something for that.
since I have removed it, the terminal shows a message "bash: /home/trusrsle/.acme.sh/acme.sh.env: No such file or directory"
I have no idea about OS environments nor acme.sh use.
I can say that programs should be installed and uninstalled.
Removing directories without explicit direction to do so is never a good idea.
Ok I installed acme.sh using curl https://get.acme.sh | sh
and uninstalled completely using acme.sh --uninstall
Do you know if that version of cPanel can get certs for you?
How to check?
The Internet knows everything...
Start with: What version of cPanel is that?
102.0 (build 25)
Then take that to the Internet...
@rg305 I want to know if the acme.sh supports RSA based cert generation. The namecheap cpanel does not support ECDSA key type. So Everytime installing a cert, I have to contact the support team to manually update on the server. They recommended RSA based cert.
Found the solution adding --keylength 2048
