How to force certbot to use HTTP for authentication instead of HTTPS?
animopticum.com
sudo certbot --authenticator webroot --preferred-challenges http --installer nginx -w /sites/animopticum.com -d animopticum.com
Plugins selected: Authenticator webroot, Installer nginx
http-01 challenge for animopticum.com
Using the webroot path /sites/animopticum.com for all unmatched domains.
Failed authorization procedure. animopticum.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://animopticum.com/.well-known/acme-challenge/6OpJlulaoZ0oXC3dtW6KUadViY212j37e0KsiXjdqAs: Error getting validation data
   Domain: animopticum.com
   Type:   connection
   Detail: Fetching
nginx/1.10.3
Ubuntu 16.04.2 LTS
I’m using a control panel to manage my site: no
Please note it’s trying to use HTTPS for some reason which does not make any sense since I’m exactly trying to obtain the certificate.
I have checked the access to files on my domain in .well-known path and everything is working great via HTTP (80 port).
Let's Encrypt will only do this if instructed by the web server with an HTTP redirect.
The reason, in your case, this is happening, is because the IPv6 variant of your website, hosted at 2a01:7e00::f03c:91ff:fee5:6bd3, is serving up this redirect:
$ curl -X GET -I -6 animopticum.com/.well-known/acme-challenge/test
Server: nginx/1.10.3
Date: Wed, 24 Jan 2018 20:58:56 GMT
Content-Type: text/html
Content-Length: 185
Location: https://animopticum.com/.well-known/acme-challenge/test
whereas the IPv4 variant doesn't:
$ curl -X GET -I -4 animopticum.com/.well-known/acme-challenge/test
HTTP/1.1 404 Not Found
Date: Wed, 24 Jan 2018 20:59:45 GMT
Content-Length: 169
Let's Encrypt will always prefer to use the AAAA record if it is present on your zone.
Oh wow, that’s weird, I did not setted up those domains for using ipv6.
Anyway, it seems it helped me to solve the issue!
Thank you a lot!
