Hi there!
I run a custom built web server on a custom built Linux. How can I just send my csr and get the crt?
That’s really all I need. It feels to me that these tools that are supposed to help make everything a lot more complex (at least in my case).
The script I downloaded from the website needs some dependencies, etc… I want it simple, how can I do that?
Thanks!
try acme.sh.
it has a command: --signcsr
acme.sh --signcsr --csr /path/to/csr -w /path/webroot/home/
You can't--Let's Encrypt doesn't work that way. You must use some form of client, be it a piece of locally-installed software (as suggested by @Neilpang), or a third-party web client like zerossl.com.
@Neilpang : Perfect thanks! Exactly what I was looking for
hi @danb35
Let’s Encrypt will allow you use you own CSRs
@barkos there are lots of clients which are fairly straight forward (pass them CSR) certbot and some of the others have a lot of additional functionality but it’s usually a matter of shopping around
ACME requires you to use a client so there’s not real way around that. Choosing a client that is fit for purpose is a bit more of a challenge
Andrei
Of course it will--with client software. As I said, you can't just upload a CSR on the LE web site and have it generate a cert; you need to use client software of one form or another.
