How to create ...?
hi, i wolud like to create a wildcardcert. for two subdomains
how did it work …?
regards
You can
1.Install any command line client that works (a list of clients https://letsencrypt.org/docs/client-options/ )
(or use web based like sslforfree.com, zerossl.com)
2.Use DNS validation , generate records for your correxponding domain.
3.input txt records to your DNS hosting.
4. Validate the record,
5. get the certificate
6. deploy it.
Thank you
(For wildcards in particular, the “clients that work” will have to be from the ACMEv2-compatible section there.)
