How to create and import certificates to weblogic adminserver
My domain is: bctbiuat.bahwancybertek.com
I ran this command: ./getssl --debug bctbiuat.bahwancybertek.com
It produced this output: certificates generated
The operating system my web server runs on is (include version): Red Hat Enterprise Linux Server release 6.2 (Santiago)
Hi @JOHN29
you have created 5 certificates with your domain name bctbiuat.bahwancybertek.com
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:bctbiuat.bahwancybertek.com&lu=cert_search
Last two today. So this part works.
So getssl (I don’t use it) should save these certificates. Perhaps you have to add the certificate manual to weblogic adminserver.
But after importing certificates in to the keystore. The browser is showing untrusted certificate.
I don’t know something about weblogic adminserver.
http://www.oracle.com/webfolder/technetwork/tutorials/obe/fmw/wls/12c/12_2_1/01-38-001-ConfiguringSSL/ConfiguringSSL.html
Doesn’t that work?
We are using weblogic server 11g
