The phrase ‘certbot files’ is confusing in this context. There are a whole bunch of files that apt remove certbot does not remove that are under /etc/letsencrypt. It is desirable that they not remove all of them since I had to hand code scripts under /etc/letsencrypt/renewal-hooks. Nevertheless, prior to apt remove certbot I made a backup of those, just in case it did remove them along with the hoped-for deletion of the problematic .conf files under /etc/letsencrypt/renewal.
Having said that, here are the messages:
2020-03-02 19:02:46,851:DEBUG:certbot.main:certbot version: 0.31.0
2020-03-02 19:02:46,851:DEBUG:certbot.main:Arguments: ['-q']
2020-03-02 19:02:46,852:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#dns-linode,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2020-03-02 19:02:46,862:DEBUG:certbot.log:Root logging level set at 30
2020-03-02 19:02:46,863:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2020-03-02 19:02:46,865:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0001.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,873:DEBUG:certbot.plugins.selection:Requested authenticator <certbot.cli._Default object at 0x7fc8d9120b38> and installer <certbot.cli._Default object at 0x7fc8d9120b38>
2020-03-02 19:02:46,882:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,884:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,885:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0002.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,889:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,890:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,891:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0003.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,895:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,896:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,897:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0004.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,900:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,901:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,902:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0005.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,906:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,907:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,908:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0006.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,911:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,912:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,913:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0007.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,916:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,917:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,918:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0008.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,921:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,922:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,923:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0009.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,926:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,927:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,928:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0010.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,931:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,932:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,933:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0011.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,936:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,937:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,938:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0012.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,941:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,942:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,943:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0013.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,946:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,946:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,947:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com-0014.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,950:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,951:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,952:INFO:certbot.storage:Attempting to parse the version 1.2.0 renewal configuration file found at /etc/letsencrypt/renewal/mydomain.com.conf with version 0.31.0 of Certbot. This might not work.
2020-03-02 19:02:46,955:INFO:certbot.renewal:Cert not yet due for renewal
2020-03-02 19:02:46,956:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2020-03-02 19:02:46,961:DEBUG:certbot.storage:Should renew, less than 30 days before certificate expiry 2020-01-21 04:17:39 UTC.
2020-03-02 19:02:46,961:INFO:certbot.renewal:Cert is due for renewal, auto-renewing...
2020-03-02 19:02:46,961:INFO:certbot.renewal:Non-interactive renewal: random delay of 318 seconds
