Nope .. well they do but that is at the web site instruction when I choose what help I want. Yes I close #1
(Apache). and the given one out of two choice
sudo certbot --apache
or.
sudo certbot certonly --apache -v
With all the fun I have been having I choose cert only
and I get this
root@triggerfish:/home/jason # apachectl start
Performing sanity check on apache24 configuration:
Syntax OK
Starting apache24.
root@triggerfish:/home/jason # sudo certbot certonly --apache -v
Unable to read ssl_module file; not disabling session tickets.
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: kasdivi.com
Requesting a certificate for kasdivi.com and 5 more domains
http-01 challenge for kasdivi.com
http-01 challenge for theoceanwindow.com
http-01 challenge for wandjbrewers.com
http-01 challenge for www.kasdivi.com
http-01 challenge for www.theoceanwindow.com
http-01 challenge for www.wandjbrewers.com
Challenge failed for domain kasdivi.com
Challenge failed for domain theoceanwindow.com
Challenge failed for domain wandjbrewers.com
Challenge failed for domain www.kasdivi.com
Challenge failed for domain www.theoceanwindow.com
Challenge failed for domain www.wandjbrewers.com
Domain: kasdivi.com
Type: connection
Detail: 209.160.65.133: Fetching http://kasdivi.com/.well-known/acme-challenge/q6EHgeUjSP_1-d2MDUd-_S09sl0pkgeH7kEGFUl6YTo: Connection refused
Domain: theoceanwindow.com
Type: connection
Detail: 209.160.64.187: Fetching http://theoceanwindow.com/.well-known/acme-challenge/_h9J52FQ6yYZDDKr7boctYypgNnYOyWUum-wcnRmmSQ: Connection refused
Domain: wandjbrewers.com
Type: connection
Detail: 209.160.65.133: Fetching http://wandjbrewers.com/.well-known/acme-challenge/5iC9qaC_HXZIQXDvRh-hAnfrQuEmZvh7G_JC5z_VKaM: Connection refused
Domain: www.kasdivi.com
Type: connection
Detail: 209.160.65.133: Fetching http://www.kasdivi.com/.well-known/acme-challenge/4D5lOj28gGb1eHIyOvrUpDn7nlZRy6uvcHHtSXnJvf4: Connection refused
Domain: www.theoceanwindow.com
Type: connection
Detail: 209.160.64.187: Fetching http://www.theoceanwindow.com/.well-known/acme-challenge/TlfqwB5YOsQUdcaE-63VS-oneRIa2D8m6uwMVHajoAw: Connection refused
Domain: www.wandjbrewers.com
Type: connection
Detail: 209.160.65.133: Fetching http://www.wandjbrewers.com/.well-known/acme-challenge/rOEHclvDgfDuNIEJCpmaskAEUT2SeiU3umhaJharYJw: Connection refused
apache24 not running? (check /var/run/httpd.pid).
Unable to restart apache using ['apachectl', 'graceful']
Encountered exception during recovery: certbot.errors.MisconfigurationError: Error while running apachectl graceful.
Back to the connectivity.
