How to clean a slate
My domain is:kasdivi.co
certbot -d theoceanwindow.com -d kasdivi.com -d wandjbrewery.com
Requesting a certificate for theoceanwindow.com and 2 more domains
Domain: theoceanwindow.com
Type: connection
Detail: 209.160.64.187: Fetching http://theoceanwindow.com/.well-known/acme-challenge/hU5ICApL7L_FEVirFkiKyEFJdtjXZs3X7vAkUL3ZR3k: Connection refused
Domain: kasdivi.com
Type: connection
Detail: 209.160.65.133: Fetching http://kasdivi.com/.well-known/acme-challenge/mBh_lnNgCob45CzlC9p-jXAnlQpgSx7pi5tSafHwl7Y: Connection refused
Domain: wandjbrewery.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for wandjbrewery.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for wandjbrewery.com - check that a DNS record exists for this domain
apache24 not running? (check /var/run/httpd.pid).
Unable to restart apache using ['apachectl', 'graceful']
Encountered exception during recovery: certbot.errors.MisconfigurationError: Error while running apachectl graceful.
root@triggerfish:/usr/local/etc/ssl/new # cd ..
root@triggerfish:/usr/local/etc/ssl # cd ../
root@triggerfish:/usr/local/etc # cd ../
root@triggerfish:/usr/local # certbot -d theoceanwindow.com -d kasdivi.com -d wandjbrewery.com
Unable to read ssl_module file; not disabling session tickets.
Blockquote
apache24
Freebsd 13.2
no
certbot 2.9.0
As state earlier abused the heck out of certbot. Certbot -- deleted shows no server. so I assume my cleaning my hand killed the information.. How do I get back to vanilla system to allow me to truly start open. I turns out iOS truly dialikes openssl self signed certificated
Is there a web server installed now?
What shows?:
sudo netstat -pant | grep -i listen
I usually start by zeroing out the last 37 sectors and the first 37 sectors of the disk (or whatever media) drive. The reinstall the OS, etc.
That is what I think of for a clean slate.
I meant for certbot.
netstat: ant: unknown or uninstrumented protocol
Fair enough @captcurrent .
Try:
netstat -an | grep -i tcp | grep -i listen
tcp6       0      0 *.443                  *.*                    LISTEN
tcp4       0      0 *.80                   *.*                    LISTEN
tcp6       0      0 *.80                   *.*                    LISTEN
tcp6       0      0 *.993                  *.*                    LISTEN
tcp4       0      0 *.993                  *.*                    LISTEN
tcp6       0      0 *.143                  *.*                    LISTEN
tcp4       0      0 *.143                  *.*                    LISTEN
tcp6       0      0 *.995                  *.*                    LISTEN
tcp4       0      0 *.995                  *.*                    LISTEN
tcp6       0      0 *.110                  *.*                    LISTEN
tcp4       0      0 *.110                  *.*                    LISTEN
tcp6       0      0 *.4190                 *.*                    LISTEN
tcp4       0      0 *.4190                 *.*                    LISTEN
tcp4       0      0 *.465                  *.*                    LISTEN
tcp4       0      0 *.587                  *.*                    LISTEN
tcp4       0      0 *.25                   *.*                    LISTEN
tcp4       0      0 127.0.0.1.11334        *.*                    LISTEN
tcp4       0      0 127.0.0.1.11332        *.*                    LISTEN
tcp4       0      0 *.9000                 *.*                    LISTEN
tcp4       0      0 127.0.0.1.783          *.*                    LISTEN
tcp6       0      0 ::1.783                *.*                    LISTEN
tcp6       0      0 ::1.6379               *.*                    LISTEN
tcp4       0      0 127.0.0.1.6379         *.*                    LISTEN
tcp4       0      0 *.3306                 *.*                    LISTEN
tcp46      0      0 *.33060                *.*                    LISTEN
tcp4       0      0 127.0.0.1.11000        *.*                    LISTEN
tcp4       0      0 *.22                   *.*                    LISTEN
tcp6       0      0 *.22                   *.*                    LISTEN
tcp46      0      0 *.21                   *.*                    LISTEN
tcp4       0      0 127.0.0.1.953          *.*                    LISTEN
tcp4       0      0 127.0.0.1.53           *.*                    LISTEN
tcp6       0      0 fe80::1%lo0.53         *.*                    LISTEN
tcp6       0      0 ::1.53                 *.*                    LISTEN
tcp4       0      0 209.160.65.133.53      *.*                    LISTEN
tcp4       0      0 209.160.64.187.53      *.*                    LISTEN
Clearly there is some kind of web server running.
Please show:
ps -ef | grep -v grep | grep -Ei 'apache|nginx|docker'
in response tope the questionnaire I said I was running apache24 with 3 virtual hosts.. kasdivi.com , theoceanwindow.com and Wandjbrewers.com
apache24
Freebsd 13.2
I am not running Nginx
oot@triggerfish:/usr/local/etc/openssl # ps -ef | grep -v grep | grep -Ei 'apache|nginx|docker'
root@triggerfish:/usr/local/etc/openssl #
That's weird!
What about?:
ps -ef | grep -v grep | grep -i 'http'
root@triggerfish:/usr/local/etc # ps -ef | grep -v grep | grep -i 'http'
the page is accessibl
hmm...
What about?:
sudo netstat -plnt
OR
sudo ss -plnt
netstat: lnt: unknown or uninstrumented protocol
root@triggerfish:/usr/local/etc # sudo ss -plnt
sudo: ss: command not found
OMG!
One last attempt:
sudo netstat -lnt
Ok couple of thins. I ahem been a and bout again
I ran your commands as root. seeing no $. I assumed he wrong way
second freebsd doesn't appear to like -netstat -lnt.
that gets you
usage: sudo -h | -K | -k | -V
usage: sudo -v [-ABkNnS] [-g group] [-h host] [-p prompt] [-u user]
usage: sudo -l [-ABkNnS] [-g group] [-h host] [-p prompt] [-U user]
            [-u user] [command [arg ...]]
usage: sudo [-ABbEHkNnPS] [-C num] [-c class] [-D directory]
            [-g group] [-h host] [-p prompt] [-R directory] [-T timeout]
            [-u user] [VAR=value] [-i | -s] [command [arg ...]]
usage: sudo -e [-ABkNnS] [-C num] [-c class] [-D directory]
            [-u user] file ...
so since i like playing where I shoulddnt I did
sudo netstat -ln
Active Internet connections
Proto Recv-Q Send-Q Local Address                                 Foreign Address                               (state)
tcp4       0      0 209.160.65.133.80                             17.58.58.21.59796                             ESTABLISHED
tcp4       0      0 209.160.64.187.80                             17.58.58.22.46518                             ESTABLISHED
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.33482                               ESTABLISHED
tcp4       0      0 127.0.0.1.33482                               127.0.0.1.6379                                ESTABLISHED
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.21331                               ESTABLISHED
tcp4       0      0 127.0.0.1.21331                               127.0.0.1.6379                                ESTABLISHED
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.43863                               ESTABLISHED
tcp4       0      0 127.0.0.1.43863                               127.0.0.1.6379                                ESTABLISHED
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.11523                               ESTABLISHED
tcp4       0      0 127.0.0.1.11523                               127.0.0.1.6379                                ESTABLISHED
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.22216                               ESTABLISHED
tcp4       0      0 127.0.0.1.22216                               127.0.0.1.6379                                ESTABLISHED
tcp4       0      0 209.160.64.187.993                            193.36.224.70.53140                           TIME_WAIT
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.47017                               TIME_WAIT
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.12828                               TIME_WAIT
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.23293                               TIME_WAIT
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.13994                               TIME_WAIT
tcp4       0      0 209.160.65.133.80                             114.119.130.248.33379                         TIME_WAIT
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.26334                               TIME_WAIT
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.35843                               TIME_WAIT
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.24460                               TIME_WAIT
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.49634                               TIME_WAIT
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.47740                               TIME_WAIT
tcp4       0      0 127.0.0.1.6379                                127.0.0.1.61865                               TIME_WAIT
tcp4       0      0 209.160.64.187.993                            186.159.108.191.54229                         ESTABLISHED
tcp4       0      0 209.160.65.133.993                            186.159.108.191.54227                         ESTABLISHED
tcp4       0      0 209.160.65.133.143                            186.159.108.191.54228                         ESTABLISHED
tcp4       0      0 209.160.65.133.993                            186.159.108.191.54226                         ESTABLISHED
tcp4       0      0 209.160.64.187.993                            186.159.108.191.54225                         ESTABLISHED
tcp4       0      0 209.160.65.133.143                            186.159.108.191.54224                         ESTABLISHED
tcp4       0      0 127.0.0.1.3306                                127.0.0.1.48198                               ESTABLISHED
tcp4       0      0 127.0.0.1.48198                               127.0.0.1.3306                                ESTABLISHED
tcp4       0      0 209.160.65.133.993                            186.159.108.191.54029                         ESTABLISHED
tcp4       0      0 209.160.64.187.993                            186.159.108.191.54027                         ESTABLISHED
tcp4       0      0 209.160.65.133.993                            186.159.108.191.54025                         ESTABLISHED
tcp4       0      0 209.160.65.133.993                            186.159.108.191.54021                         ESTABLISHED
tcp4       0      0 209.160.64.187.993                            186.159.108.191.54026                         ESTABLISHED
tcp4       0      0 209.160.65.133.143                            186.159.108.191.54024                         ESTABLISHED
tcp4       0      0 209.160.65.133.993                            186.159.108.191.54022                         ESTABLISHED
tcp4       0      0 209.160.65.133.143                            186.159.108.191.54020                         ESTABLISHED
tcp4       0      0 209.160.65.133.22                             186.159.108.191.52808                         ESTABLISHED
tcp4       0     44 209.160.65.133.22                             186.159.108.191.59656                         ESTABLISHED
udp4       0      0 209.160.64.187.26932                          66.36.226.110.53
udp4       0      0 209.160.64.187.61909                          66.36.226.110.53
udp4       0      0 209.160.64.187.53669                          66.36.226.110.53
udp4       0      0 209.160.64.187.26439                          66.36.226.110.53
udp4       0      0 209.160.64.187.28255                          66.36.226.110.53
udp4       0      0 209.160.64.187.15891                          66.36.226.110.53
udp4       0      0 209.160.64.187.34080                          66.36.226.110.53
udp4       0      0 209.160.64.187.60227                          66.36.226.110.53
udp4       0      0 209.160.64.187.29322                          66.36.226.110.53
udp4       0      0 209.160.64.187.58870                          66.36.226.110.53
udp4       0      0 209.160.64.187.49935                          66.36.226.110.53
udp4       0      0 209.160.64.187.53819                          66.36.226.110.53
udp4       0      0 209.160.64.187.34929                          66.36.226.110.53
udp4       0      0 209.160.64.187.16752                          66.36.226.110.53
udp4       0      0 209.160.64.187.28184                          66.36.226.110.53
udp4       0      0 209.160.64.187.42145                          66.36.226.110.53
udp4       0      0 209.160.64.187.21698                          66.36.226.110.53
udp4       0      0 209.160.64.187.17940                          66.36.226.110.53
udp4       0      0 209.160.64.187.12471                          66.36.226.110.53
udp4       0      0 209.160.64.187.10173                          66.36.226.110.53
udp4       0      0 209.160.64.187.41071                          66.36.226.110.53
udp4       0      0 209.160.64.187.27540                          66.36.226.110.53
udp4       0      0 209.160.64.187.25759                          66.36.226.110.53
udp4       0      0 209.160.64.187.47452                          66.36.226.110.53
udp4       0      0 209.160.64.187.19307                          66.36.226.110.53
udp4       0      0 209.160.64.187.26137                          66.36.226.110.53
udp4       0      0 209.160.64.187.62371                          66.36.226.110.53
udp4       0      0 209.160.64.187.12076                          66.36.226.110.53
udp4       0      0 209.160.64.187.37154                          66.36.226.110.53
udp4       0      0 209.160.64.187.61414                          66.36.226.110.53
udp4       0      0 209.160.64.187.34563                          66.36.226.110.53
udp4       0      0 209.160.64.187.50318                          66.36.226.110.53
udp4       0      0 127.0.0.1.53                                  *.*
udp6       0      0 fe80::1%lo0.53                                *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
udp4       0      0 209.160.65.133.53                             *.*
udp4       0      0 209.160.64.187.53                             *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
udp6       0      0 ::1.53                                        *.*
Active UNIX domain sockets
Address          Type   Recv-Q Send-Q            Inode             Conn             Refs          Nextref Addr
fffff80228e6b000 stream      0      0                0 fffff80008574700                0                0
fffff80008574700 stream      0      0                0 fffff80228e6b000                0                0
fffff8039d879b00 stream      0      0                0 fffff80008224600                0                0 /var/run/dovecot/stats-writer
fffff80008224600 stream      0      0                0 fffff8039d879b00                0                0
fffff80008762900 stream      0      0                0 fffff800082ab400                0                0
fffff800082ab400 stream      0      0                0 fffff80008762900                0                0
fffff80243237500 stream      0      0                0 fffff800086eac00                0                0 /var/run/dovecot/stats-writer
fffff800086eac00 stream      0      0                0 fffff80243237500                0                0
fffff80120947600 stream      0      0                0 fffff8000856c100                0                0
fffff8000856c100 stream      0      0                0 fffff80120947600                0                0
fffff800475e8c00 stream      0      0                0 fffff80078cad400                0                0 /var/run/dovecot/stats-writer
fffff80078cad400 stream      0      0                0 fffff800475e8c00                0                0
fffff800082ab900 stream      0      0                0 fffff800082aa100                0                0
fffff800082aa100 stream      0      0                0 fffff800082ab900                0                0
fffff8024334c700 stream      0      0                0 fffff8000801ac00                0                0 /var/run/dovecot/stats-writer
fffff8000801ac00 stream      0      0                0 fffff8024334c700                0                0
fffff802394a4600 stream      0      0                0 fffff800475e4400                0                0
fffff800475e4400 stream      0      0                0 fffff802394a4600                0                0
fffff800082abe00 stream      0      0                0 fffff80078cadb00                0                0 /var/run/dovecot/stats-writer
fffff80078cadb00 stream      0      0                0 fffff800082abe00                0                0
fffff800475e9300 stream      0      0                0 fffff800475e5600                0                0 /var/run/dovecot/stats-writer
fffff800475e5600 stream      0      0                0 fffff800475e9300                0                0
fffff80008942200 stream      0      0                0 fffff80243237000                0                0
fffff80243237000 stream      0      0                0 fffff80008942200                0                0
fffff801a8e59400 stream      0      0                0 fffff800088bb700                0                0
fffff800088bb700 stream      0      0                0 fffff801a8e59400                0                0
fffff800082aeb00 stream      0      0                0 fffff801a8e59d00                0                0 /var/run/dovecot/anvil
fffff801a8e59d00 stream      0      0                0 fffff800082aeb00                0                0
fffff800475ecb00 stream      0      0                0 fffff8039d690c00                0                0 /var/run/dovecot/stats-writer
fffff8039d690c00 stream      0      0                0 fffff800475ecb00                0                0
fffff80243214b00 stream      0      0                0 fffff80008b5d700                0                0 /var/run/dovecot/config
fffff80008b5d700 stream      0      0                0 fffff80243214b00                0                0
fffff800475e9b00 stream      0      0                0 fffff80008b69500                0                0 /var/run/dovecot/anvil
fffff80008b69500 stream      0      0                0 fffff800475e9b00                0                0
fffff80078890500 stream      0      0                0 fffff800082b1700                0                0 /var/run/dovecot/stats-writer
fffff800082b1700 stream      0      0                0 fffff80078890500                0                0
fffff80008218d00 stream      0      0                0 fffff8024334c500                0                0 /var/run/dovecot/config
fffff8024334c500 stream      0      0                0 fffff80008218d00                0                0
fffff80008218c00 stream      0      0                0 fffff800475ed200                0                0 /var/run/dovecot/anvil
fffff800475ed200 stream      0      0                0 fffff80008218c00                0                0
fffff800475eac00 stream      0      0                0 fffff800082b4e00                0                0 /var/run/dovecot/stats-writer
fffff800082b4e00 stream      0      0                0 fffff800475eac00                0                0
fffff80008b6ca00 stream      0      0                0 fffff8012087b100                0                0 /var/run/dovecot/config
fffff8012087b100 stream      0      0                0 fffff80008b6ca00                0                0
fffff800475e5c00 stream      0      0                0 fffff80120740200                0                0 /var/run/dovecot/anvil
fffff80120740200 stream      0      0                0 fffff800475e5c00                0                0
fffff800475ea400 stream      0      0                0 fffff80008768300                0                0 /var/run/dovecot/stats-writer
fffff80008768300 stream      0      0                0 fffff800475ea400                0                0
fffff80120742300 stream      0      0                0 fffff800475eb000                0                0 /var/run/dovecot/config
fffff800475eb000 stream      0      0                0 fffff80120742300                0                0
fffff800475e8a00 stream      0      0                0 fffff80120871c00                0                0 /var/run/dovecot/anvil
fffff80120871c00 stream      0      0                0 fffff800475e8a00                0                0
fffff80078da6900 stream      0      0                0 fffff800475eee00                0                0 /var/run/dovecot/stats-writer
fffff800475eee00 stream      0      0                0 fffff80078da6900                0                0
fffff80120940500 stream      0      0                0 fffff800475e4100                0                0 /var/run/dovecot/config
fffff800475e4100 stream      0      0                0 fffff80120940500                0                0
fffff800475e6600 stream      0      0                0 fffff800475e8000                0                0 /var/run/dovecot/anvil
fffff800475e8000 stream      0      0                0 fffff800475e6600                0                0
fffff80120976600 stream      0      0                0 fffff80008b5a900                0                0 /var/run/dovecot/stats-writer
fffff80008b5a900 stream      0      0                0 fffff80120976600                0                0
fffff8012073f100 stream      0      0                0 fffff80008217300                0                0 /var/run/dovecot/config
fffff80008217300 stream      0      0                0 fffff8012073f100                0                0
fffff8012094bc00 stream      0      0                0 fffff8039df24d00                0                0 /var/run/dovecot/anvil-auth-penalty
fffff8039df24d00 stream      0      0                0 fffff8012094bc00                0                0
fffff80078851d00 stream      0      0                0 fffff80008b5c400                0                0 /var/run/dovecot/stats-writer
fffff80008b5c400 stream      0      0                0 fffff80078851d00                0                0
fffff800475e7000 stream      0      0                0 fffff8012093f700                0                0 /var/run/dovecot/stats-writer
fffff8012093f700 stream      0      0                0 fffff800475e7000                0                0
fffff800082ab600 stream      0      0                0 fffff800475e7a00                0                0
fffff800475e7a00 stream      0      0                0 fffff800082ab600                0                0
fffff800082ab800 stream      0      0                0 fffff800475e2100                0                0 /var/run/dovecot/anvil
fffff800475e2100 stream      0      0                0 fffff800082ab800                0                0
fffff800082b7400 stream      0      0                0 fffff80008b66c00                0                0 /var/run/dovecot/stats-writer
fffff80008b66c00 stream      0      0                0 fffff800082b7400                0                0
fffff8000821eb00 stream      0      0                0 fffff800475eb300                0                0 /var/run/dovecot/config
fffff800475eb300 stream      0      0                0 fffff8000821eb00                0                0
fffff80243214500 stream      0      0                0 fffff80008218400                0                0 /var/run/dovecot/stats-writer
fffff80008218400 stream      0      0                0 fffff80243214500                0                0
fffff800082abc00 stream      0      0                0 fffff80120870600                0                0 /var/run/dovecot/stats-writer
fffff80120870600 stream      0      0                0 fffff800082abc00                0                0
fffff800082abd00 stream      0      0                0 fffff800475ece00                0                0
fffff800475ece00 stream      0      0                0 fffff800082abd00                0                0
fffff80008217a00 stream      0      0                0 fffff80239a56100                0                0
fffff80239a56100 stream      0      0                0 fffff80008217a00                0                0
fffff80228e6bb00 stream      0      0                0 fffff80008220300                0                0 /var/run/dovecot/stats-writer
fffff80008220300 stream      0      0                0 fffff80228e6bb00                0                0
fffff80008b5e700 stream      0      0                0 fffff8012086b500                0                0
fffff8012086b500 stream      0      0                0 fffff80008b5e700                0                0
fffff8000821dd00 stream      0      0                0 fffff80008765200                0                0 /var/run/dovecot/stats-writer
fffff80008765200 stream      0      0                0 fffff8000821dd00                0                0
fffff800082ab500 stream      0      0                0 fffff801a8e59200                0                0
fffff801a8e59200 stream      0      0                0 fffff800082ab500                0                0
fffff8012086ba00 stream      0      0                0 fffff80243053800                0                0 /var/run/dovecot/stats-writer
fffff80243053800 stream      0      0                0 fffff8012086ba00                0                0
fffff80120870a00 stream      0      0                0 fffff800082afb00                0                0 /var/run/dovecot/stats-writer
fffff800082afb00 stream      0      0                0 fffff80120870a00                0                0
fffff80078851600 stream      0      0                0 fffff800475e9800                0                0
fffff800475e9800 stream      0      0                0 fffff80078851600                0                0
fffff80120879700 stream      0      0                0 fffff800475ed300                0                0
fffff800475ed300 stream      0      0                0 fffff80120879700                0                0
fffff80008b5a100 stream      0      0                0 fffff800475e8d00                0                0 /var/run/dovecot/stats-writer
fffff800475e8d00 stream      0      0                0 fffff80008b5a100                0                0
fffff800475ed100 stream      0      0                0 fffff800475ed000                0                0
fffff800475ed000 stream      0      0                0 fffff800475ed100                0                0
fffff8012094e100 stream      0      0                0 fffff80008b62c00                0                0 /var/run/dovecot/anvil
fffff80008b62c00 stream      0      0                0 fffff8012094e100                0                0
fffff80243611900 stream      0      0                0 fffff80008763e00                0                0 /var/run/dovecot/stats-writer
fffff80008763e00 stream      0      0                0 fffff80243611900                0                0
fffff80008217700 stream      0      0                0 fffff80243526d00                0                0 /var/run/dovecot/config
fffff80243526d00 stream      0      0                0 fffff80008217700                0                0
fffff80228e6b600 stream      0      0                0 fffff800475e1700                0                0 /var/run/dovecot/anvil
fffff800475e1700 stream      0      0                0 fffff80228e6b600                0                0
fffff800475eae00 stream      0      0                0 fffff80008b57b00                0                0 /var/run/dovecot/stats-writer
fffff80008b57b00 stream      0      0                0 fffff800475eae00                0                0
fffff80008768c00 stream      0      0                0 fffff80120940200                0                0 /var/run/dovecot/config
fffff80120940200 stream      0      0                0 fffff80008768c00                0                0
fffff80078cadd00 stream      0      0                0 fffff8000821d100                0                0 /var/run/dovecot/anvil
fffff8000821d100 stream      0      0                0 fffff80078cadd00                0                0
fffff80008765400 stream      0      0                0 fffff8007853c300                0                0 /var/run/dovecot/stats-writer
fffff8007853c300 stream      0      0                0 fffff80008765400                0                0
fffff80008218000 stream      0      0                0 fffff800475ea200                0                0 /var/run/dovecot/config
fffff800475ea200 stream      0      0                0 fffff80008218000                0                0
fffff800088bb800 stream      0      0                0 fffff80008224800                0                0 /var/run/dovecot/anvil
fffff80008224800 stream      0      0                0 fffff800088bb800                0                0
fffff80008b67d00 stream      0      0                0 fffff800475e7300                0                0 /var/run/dovecot/stats-writer
fffff800475e7300 stream      0      0                0 fffff80008b67d00                0                0
fffff800475e8300 stream      0      0                0 fffff80008763c00                0                0 /var/run/dovecot/config
fffff80008763c00 stream      0      0                0 fffff800475e8300                0                0
fffff80120941a00 stream      0      0                0 fffff8012086f300                0                0 /var/run/dovecot/anvil
fffff8012086f300 stream      0      0                0 fffff80120941a00                0                0
fffff800088ba100 stream      0      0                0 fffff8012093fd00                0                0 /var/run/dovecot/stats-writer
fffff8012093fd00 stream      0      0                0 fffff800088ba100                0                0
fffff80008218800 stream      0      0                0 fffff800475e9700                0                0 /var/run/dovecot/config
fffff800475e9700 stream      0      0                0 fffff80008218800                0                0
fffff80008b57a00 stream      0      0                0 fffff80120947800                0                0 /var/run/dovecot/anvil
fffff80120947800 stream      0      0                0 fffff80008b57a00                0                0
fffff8012093f900 stream      0      0                0 fffff800082aa400                0                0 /var/run/dovecot/stats-writer
fffff800082aa400 stream      0      0                0 fffff8012093f900                0                0
fffff800082ab300 stream      0      0                0 fffff80228e6b700                0                0 /var/run/dovecot/config
fffff80228e6b700 stream      0      0                0 fffff800082ab300                0                0
fffff80120740900 stream      0      0                0 fffff8000821c600                0                0 /var/run/dovecot/anvil
fffff8000821c600 stream      0      0                0 fffff80120740900                0                0
fffff802394a4100 stream      0      0                0 fffff800082ac900                0                0 /var/run/dovecot/stats-writer
fffff800082ac900 stream      0      0                0 fffff802394a4100                0                0
fffff80120870500 stream      0      0                0 fffff8012094c200                0                0 /var/run/dovecot/config
fffff8012094c200 stream      0      0                0 fffff80120870500                0                0
fffff80078af5b00 stream      0      0 fffff801a8c131e8                0                0                0 /var/run/dovecot/master
fffff80008b5dc00 stream      0      0 fffff801a8c135b8                0                0                0 /var/run/dovecot/quota-warning
fffff8012086f600 stream      0      0 fffff801a8c137a0                0                0                0 /var/run/dovecot/anvil-auth-penalty
fffff80120871600 stream      0      0 fffff801a8c13988                0                0                0 /var/run/dovecot/anvil
fffff80120976e00 stream      0      0 fffff801a8c13b70                0                0                0 /var/run/dovecot/auth-worker
fffff800475e0b00 stream      0      0 fffff801a8c13d58                0                0                0 /var/spool/postfix/private/auth
fffff800082ad400 stream      0      0 fffff801a8b37000                0                0                0 /var/run/dovecot/auth-master
fffff800475eb700 stream      0      0 fffff801a8899000                0                0                0 /var/run/dovecot/auth-userdb
fffff800475e7600 stream      0      0 fffff801a88991e8                0                0                0 /var/run/dovecot/auth-client
fffff8012086fc00 stream      0      0 fffff801a88993d0                0                0                0 /var/run/dovecot/auth-login
fffff8000821db00 stream      0      0 fffff801a88995b8                0                0                0 /var/run/dovecot/token-login/tokenlogin
fffff80008b65b00 stream      0      0 fffff803c97d51e8                0                0                0 /var/run/dovecot/login/login
fffff80008221600 stream      0      0 fffff803cda3ad58                0                0                0 /var/run/dovecot/config
fffff80008564400 stream      0      0 fffff80061308b70                0                0                0 /var/run/dovecot/dict-async
fffff8012086ca00 stream      0      0 fffff802286a2d58                0                0                0 /var/run/dovecot/dict
fffff80008940200 stream      0      0 fffff80120ffe1e8                0                0                0 /var/run/dovecot/director-userdb
fffff80008762a00 stream      0      0 fffff800612c63d0                0                0                0 /var/run/dovecot/director-admin
fffff80243237100 stream      0      0 fffff800612c8d58                0                0                0 /var/run/dovecot/login/dns-client
fffff80243214600 stream      0      0 fffff800612c83d0                0                0                0 /var/run/dovecot/dns-client
fffff80120942e00 stream      0      0 fffff800612c6d58                0                0                0 /var/run/dovecot/doveadm-server
fffff80078cc5000 stream      0      0 fffff80120ffe000                0                0                0 /var/run/dovecot/imap-hibernate
fffff8024334c400 stream      0      0 fffff800613087a0                0                0                0 /var/run/dovecot/imap-urlauth
fffff800475e2300 stream      0      0 fffff8006125a3d0                0                0                0 /var/run/dovecot/token-login/imap-urlauth
fffff800475e7500 stream      0      0 fffff800613085b8                0                0                0 /var/run/dovecot/imap-urlauth-worker
fffff8012087b800 stream      0      0 fffff800612eb7a0                0                0                0 /var/run/dovecot/imap-master
fffff80008221100 stream      0      0 fffff800612e7988                0                0                0 /var/run/dovecot/login/imap
fffff80008b5c700 stream      0      0 fffff803cd5467a0                0                0                0 /var/run/dovecot/indexer
fffff80120940c00 stream      0      0 fffff80061342d58                0                0                0 /var/run/dovecot/indexer-worker
fffff80008766400 stream      0      0 fffff803d80e4d58                0                0                0 /var/run/dovecot/login/ipc-proxy
fffff800082aa600 stream      0      0 fffff803cf7bf000                0                0                0 /var/run/dovecot/ipc
fffff8024353e600 stream      0      0 fffff8018fc07988                0                0                0 /var/spool/postfix/private/dovecot-lmtp
fffff80008763a00 stream      0      0 fffff803cd3b7b70                0                0                0 /var/run/dovecot/lmtp
fffff80008226d00 stream      0      0 fffff803afff57a0                0                0                0 /var/run/dovecot/log-errors
fffff800475e9d00 stream      0      0 fffff803cf7cbb70                0                0                0 /var/run/dovecot/old-stats
fffff80243381c00 stream      0      0 fffff803cd9b67a0                0                0                0 /var/run/dovecot/login/pop3
fffff80008b6b300 stream      0      0 fffff8018fc067a0                0                0                0 /var/run/dovecot/replication-notify
fffff8012086e600 stream      0      0 fffff8006135d5b8                0                0                0 /var/run/dovecot/replicator
fffff80008224100 stream      0      0 fffff8006141e1e8                0                0                0 /var/run/dovecot/login/stats-writer
fffff8000821e900 stream      0      0 fffff803c97237a0                0                0                0 /var/run/dovecot/stats-writer
fffff80008b56900 stream      0      0 fffff803aff27988                0                0                0 /var/run/dovecot/stats-reader
fffff800475e2b00 stream      0      0 fffff803cd9697a0                0                0                0 /var/run/dovecot/login/sieve
fffff8039d970c00 stream      0      0                0 fffff80008b5f200                0                0
fffff80008b5f200 stream      0      0                0 fffff8039d970c00                0                0
fffff80008766c00 stream      0      0 fffff80061308d58                0                0                0 private/dovecot
fffff80008b66900 stream      0      0 fffff800612edb70                0                0                0 private/scache
fffff8012086d700 stream      0      0 fffff800612edd58                0                0                0 private/anvil
fffff80008b57500 stream      0      0 fffff800612d9000                0                0                0 private/lmtp
fffff80008b57000 stream      0      0 fffff800612d91e8                0                0                0 private/virtual
fffff80008b6ad00 stream      0      0 fffff800612d97a0                0                0                0 private/local
fffff80008b6ac00 stream      0      0 fffff800612d9b70                0                0                0 private/discard
fffff80008b6a900 stream      0      0 fffff800612e53d0                0                0                0 private/retry
fffff80008b6a800 stream      0      0 fffff800612e55b8                0                0                0 private/error
fffff80008b6a500 stream      0      0 fffff800612e5d58                0                0                0 public/showq
fffff80008b6a400 stream      0      0 fffff800612cf1e8                0                0                0 private/relay
fffff80008b6a300 stream      0      0 fffff800612cf988                0                0                0 private/smtp
fffff80008b6a200 stream      0      0 fffff8032946a000                0                0                0 private/proxywrite
fffff80008b6a100 stream      0      0 fffff8006141cb70                0                0                0 private/proxymap
fffff80008b6a000 stream      0      0 fffff803c92461e8                0                0                0 public/flush
fffff80008b5ce00 stream      0      0 fffff803ca30b3d0                0                0                0 private/verify
fffff80008b5cd00 stream      0      0 fffff8006141e000                0                0                0 private/trace
fffff80008b5cc00 stream      0      0 fffff803cd968000                0                0                0 private/defer
fffff80008b5cb00 stream      0      0 fffff803cf22f3d0                0                0                0 private/bounce
fffff80008b5ca00 stream      0      0 fffff803cf2535b8                0                0                0 private/rewrite
fffff80008b5c900 stream      0      0 fffff803cf2467a0                0                0                0 private/tlsmgr
fffff80008b5c600 stream      0      0 fffff803c9bd87a0                0                0                0 public/qmgr
fffff80008b5c500 stream      0      0 fffff803c9e4c5b8                0                0                0 public/cleanup
fffff80008b5c200 stream      0      0 fffff803cd5b1d58                0                0                0 public/pickup
fffff80008b5c100 stream      0      0 fffff803c26f5988                0                0                0 private/spf-policy
fffff80008b5c000 stream      0      0 fffff8018fb7f000                0                0                0 private/tlsproxy
fffff80008b5de00 stream      0      0 fffff800651a4b70                0                0                0 private/dnsblog
fffff80008574e00 stream      0      0 fffff803c4244000                0                0                0 private/smtpd
fffff80008762300 stream      0      0                0 fffff8012094d500                0                0
fffff8012094d500 stream      0      0                0 fffff80008762300                0                0
fffff80008b5e400 stream      0      0                0                0                0                0
fffff80078cade00 stream      0      0                0 fffff80008b65600                0                0
fffff80008b65600 stream      0      0                0 fffff80078cade00                0                0
fffff8000876c500 stream      0      0                0                0                0                0
fffff800475e1100 stream      0      0 fffff8022817dd58                0                0                0 /var/run/rspamd/rspamd.sock
fffff800475e1600 stream      0      0 fffff801d6722000                0                0                0 /var/db/rspamd/rspamd.sock
fffff8012086c900 stream      0      0                0 fffff80008218a00                0                0
fffff80008218a00 stream      0      0                0 fffff8012086c900                0                0
fffff8012086d100 stream      0      0                0 fffff8012086d200                0                0
fffff8012086d200 stream      0      0                0 fffff8012086d100                0                0
fffff800475e1800 stream      0      0                0 fffff800475e1900                0                0
fffff800475e1900 stream      0      0                0 fffff800475e1800                0                0
fffff8012086d900 stream      0      0                0                0                0                0
fffff800475e1a00 stream      0      0                0 fffff800475e1b00                0                0
fffff800475e1b00 stream      0      0                0 fffff800475e1a00                0                0
fffff800475e1c00 stream      0      0                0 fffff800475e1d00                0                0
fffff800475e1d00 stream      0      0                0 fffff800475e1c00                0                0
fffff800082aac00 stream      0      0 fffff80120387000                0                0                0 /tmp/mysql.sock
fffff800475e0100 stream      0      0 fffff80008b52988                0                0                0 /tmp/mysqlx.sock
fffff80008b66600 stream      0      0 fffff80047bc6d58                0                0                0 /var/run/proftpd.sock
fffff800475e0600 stream      0      0 fffff8000861d7a0                0                0                0 /var/run/devd.pipe
fffff80008767300 dgram       0      0                0 fffff800082aad00                0 fffff800787bd400
fffff800787bd400 dgram       0      0                0 fffff800082aad00                0 fffff8012073fe00
fffff8012073fe00 dgram       0      0                0 fffff800082aad00                0 fffff80008a38100
fffff80008a38100 dgram       0      0                0 fffff800082aad00                0 fffff800475ebe00
fffff800475ebe00 dgram       0      0                0 fffff800082aad00                0 fffff800475e2900
fffff800475e2900 dgram       0      0                0 fffff800082aad00                0 fffff8012087ae00
fffff80008571200 dgram       0      0 fffff800612ed7a0                0                0                0 public/postlog
fffff8012087ae00 dgram       0      0                0 fffff800082aad00                0 fffff8012073f000
fffff8012073f000 dgram       0      0                0 fffff800082aad00                0 fffff8012086da00
fffff800082aa700 dgram       0      0                0 fffff800475e0300                0 fffff800084fa300
fffff8012086da00 dgram       0      0                0 fffff800082aad00                0 fffff80008216800
fffff800084fa300 dgram       0      0                0 fffff800475e0300                0 fffff800082aab00
fffff800082aab00 dgram       0      0                0 fffff800475e0300                0                0
fffff80008216800 dgram       0      0                0 fffff800082aad00                0 fffff80008b66700
fffff80008b66700 dgram       0      0                0 fffff800082aad00                0                0
fffff800082aad00 dgram       0      0 fffff8004795a988                0 fffff80008767300                0 /var/run/logpriv
fffff800475e0300 dgram       0      0 fffff8004795ab70                0 fffff800082aa700                0 /var/run/log
fffff800475e2c00 seqpac      0      0                0 fffff800475e2d00                0                0
fffff800475e2d00 seqpac      0      0                0 fffff800475e2c00                0                0
fffff800475e2e00 seqpac      0      0                0 fffff800475e1000                0                0
fffff800475e1000 seqpac      0      0                0 fffff800475e2e00                0                0
fffff800475e1200 seqpac      0      0                0 fffff800475e1300                0                0
fffff800475e1300 seqpac      0      0                0 fffff800475e1200                0                0
fffff800475e1400 seqpac      0      0                0 fffff800475e1500                0                0
fffff800475e1500 seqpac      0      0                0 fffff800475e1400                0                0
fffff800475e0500 seqpac      0      0 fffff8000861d5b8
I give up.
It's not showing any of the ports that it's listening on.
Nor any of the services using the ports.
You may be able to get something with lsof -i (especially as root).
freebsd doesn't like that command
OK I know (OK I assume I had this workimg) before I broke things trying to upgrade the mail server
I do use IPFW as a firewall
00010 allow ip from any to any via lo0
00013 allow tcp from any to any 443 in setup keep-state :default
00014 allow tcp from any to any 443 out setup keep-state :default
00015 allow ip from table(1) to any
00016 allow tcp from any to any 9000 in setup keep-state :default
00017 allow tcp from any to any 9000 out setup keep-state :default
00018 deny log ip from table(22) to any
00020 deny ip from any to 127.0.0.0/8
00030 deny ip from 127.0.0.0/8 to any
00045 deny ip from 176.111.0.0/16 to any
00050 check-state :default
00060 allow tcp from any to any established
00070 allow ip from any to any out keep-state :default
00080 allow icmp from any to any
00110 allow tcp from any to any 21 in setup keep-state :default
00120 allow tcp from any to any 21 out setup keep-state :default
00130 allow tcp from any to any 22 in setup keep-state :default
00140 allow tcp from any to any 22 out setup keep-state :default
00150 allow tcp from any to any 25 in setup keep-state :default
00160 allow tcp from any to any 25 out setup keep-state :default
00170 allow udp from any to any 53 in keep-state :default
00175 allow tcp from any to any 53 in setup keep-state :default
00180 allow udp from any to any 53 out setup keep-state :default
00185 allow tcp from any to any 53 out setup keep-state :default
00200 allow tcp from any to any 80 in setup keep-state :default
00210 allow tcp from any to any 80 out setup keep-state :default
00215 allow tcp from any to any 110 in setup keep-state :default
00216 allow tcp from any to any 110 out setup keep-state :default
00220 allow tcp from any to any 143 in setup keep-state :default
00225 allow tcp from any to any 143 out setup keep-state :default
00227 allow tcp from any to any 443 in setup keep-state :default
00228 allow tcp from any to any 443 out setup keep-state :default
00230 allow tcp from any to any 465 in setup keep-state :default
00235 allow tcp from any to any 465 out setup keep-state :default
00250 allow tcp from any to any 587 in setup keep-state :default
00255 allow tcp from any to any 587 out setup keep-state :default
00260 allow tcp from any to any 993 in setup keep-state :default
00265 allow tcp from any to any 993 out setup keep-state :default
00270 allow tcp from any to any 995 in setup keep-state :default
00275 allow tcp from any to any 995 out setup keep-state :default
00500 deny log ip from any to any
65535 deny ip from any to any
  1. Should I stop the firewall and try installing certbot again?
  2. In the dim reaches of my memory I sort of remembering trying to move away from port 25 to port 2500 To avoid attacks. but I see nosing of that here
Sorry to be a pain.. I sort of have dovecots SSL mechanism working based on the guidance on the dovecot web page
