Continuing the discussion from Domain name mismatch on shared host - used gethttpsforfree.com:
I would like to remove a mismatched certificate (I obtained as discussed in the topic above) and clean up my files before moving to a new non-shared hosting plan.
Before getting this certificate via https://www.gethttpsforfree.com/, I had unsuccessfully tried certbot-auto, so I’ve created additional files that I may need to remove there too.
Will removing my etc/vinyldecalsuperstore.com/ssl folder be enough? I’d like ssllabs.com to show NO CERTIFICATE rather than a mismatch if possible.
Where else should I remove files? I’ve got a long list of files created during my trials of obtaining my mismatched cert.
Are there removal codes that would be better?
Thank you
