@ovunque
Please retry the last grep search again.
grep -ERi 'posthook|renewhook'
_savedomainconf "Le_PostHook" "$_post_hook" "base64" _savedomainconf "Le_RenewHook" "$_renew_hook" "base64" Le_PostHook="$(_readdomainconf Le_PostHook)" Le_RenewHook="$(_readdomainconf Le_RenewHook)" issue "$Le_Webroot" "$Le_Domain" "$Le_Alt" "$Le_Keylength" "$Le_RealCertPath" "$Le_RealKeyPath" "$Le_RealCACertPath" "$Le_ReloadCmd" "$Le_RealFullChainPath" "$Le_PreHook" "$Le_PostHook" "$Le_RenewHook" "$Le_LocalAddress" "$Le_ChallengeAlias"
This is not what I expected.
Maybe I’m looking in the wrong place…
Please show:
find / -name born2.run.conf
Only one result
~/.acme.sh/born2.run/born2.run.conf
(In case you're wondering, can't run a find from / because of the shared hosting. Has to start from home dir)
(Re video game: I broke the suspense by trying to get this site up and running on a node server. Certs are easier there. You beat me to it.)
Following that folder structure, list the .conf file of the domain you renewed with the hook cpanel -f
and then also show the contents.
ls -l ~/.acme.sh/domain.name/domain.name.conf
cat ~/.acme.sh/domain.name/domain.name.conf
Results:
~/.acme.sh/trillionpictures.com/trillionpictures.com.conf
Are you also playing a game?
I asked you to list the file and show the contents of it.
ls -l ~/.acme.sh/trillionpictures.com/trillionpictures.com.conf
cat ~/.acme.sh/trillionpictures.com/trillionpictures.com.conf
This is becoming a movie.
A really long one.
longer than…
tora! tora! tora!
Results:
Le_Domain='trillionpictures.com'
Le_Alt='www.trillionpictures.com,totallypostal.net,www.totallypostal.net,starsandstrife.com,www.starsandstrife.com,feathercollectionproject.com,www.feathercollectionproject.com,www.born2.run,born2.run,fixitamerica.org,www.fixitamerica.org,keeperofthedream.net,www.keeperofthedream.net,opq-design.com,www.opq-design.com,radical4.media,www.radical4.media,radical4media.com,www.radical4media.com,samself.com,www.samself.com,savingbarbarasizemore.com,www.savingbarbarasizemore.com'
Le_Webroot='~/public_html/'
Le_PreHook=''
Le_PostHook=''
Le_RenewHook=''
Le_Keylength=''
Le_OrderFinalize='https://acme-v02.api.letsencrypt.org/acme/finalize/57630353/5225577689'
Le_LinkOrder='https://acme-v02.api.letsencrypt.org/acme/order/57630353/5225577689'
Le_LinkCert='https://acme-v02.api.letsencrypt.org/acme/cert/0482467a217f2d41453695345280f85702ae'
Le_CertCreateTime='1600313810'
Le_CertCreateTimeStr='Thu Sep 17 03:36:50 UTC 2020'
Le_NextRenewTimeStr='Mon Nov 16 03:36:50 UTC 2020'
Le_NextRenewTime='1605411410'
Le_DeployHook='cpanel_uapi,'
I started at 8am on this.
That should have been shown... ![]()
I think I missed something...
Try:
grep -ERi 'posthook|renewhook' ~/.acme.sh/
[the dot after the slash may have hidden that folder]
You also failed to show (again) - PUT DOWN THE TV REMOTE - LOL
~/.acme.sh/munich72.trillionpictures.com/munich72.trillionpictures.com.conf:Le_PostHook='' ~/.acme.sh/munich72.trillionpictures.com/munich72.trillionpictures.com.conf:Le_RenewHook='' ~/.acme.sh/longplay.trillionpictures.com/longplay.trillionpictures.com.conf:Le_PostHook='' ~/.acme.sh/longplay.trillionpictures.com/longplay.trillionpictures.com.conf:Le_RenewHook='' ~/.acme.sh/sevendeadlysins.trillionpictures.com/sevendeadlysins.trillionpictures.com.conf:Le_PostHook='' ~/.acme.sh/sevendeadlysins.trillionpictures.com/sevendeadlysins.trillionpictures.com.conf:Le_RenewHook='' ~/.acme.sh/starsandstrife.com/starsandstrife.com.conf:Le_PostHook='' ~/.acme.sh/starsandstrife.com/starsandstrife.com.conf:Le_RenewHook='' ~/.acme.sh/trillionpictures.com/trillionpictures.com.conf:Le_PostHook='' ~/.acme.sh/trillionpictures.com/trillionpictures.com.conf:Le_RenewHook='' ~/.acme.sh/www.trillionpictures.com/www.trillionpictures.com.conf.removed:Le_PostHook='' ~/.acme.sh/www.trillionpictures.com/www.trillionpictures.com.conf.removed:Le_RenewHook='' ~/.acme.sh/runwithme.trillionpictures.com/runwithme.trillionpictures.com.conf:Le_PostHook='' ~/.acme.sh/runwithme.trillionpictures.com/runwithme.trillionpictures.com.conf:Le_RenewHook='' ~/.acme.sh/born2.run/born2.run.conf.removed:Le_PostHook='' ~/.acme.sh/born2.run/born2.run.conf.removed:Le_RenewHook='' ~/.acme.sh/born2.run/born2.run.conf:Le_PostHook='' ~/.acme.sh/born2.run/born2.run.conf:Le_RenewHook='' ~/.acme.sh/acme.sh: _savedomainconf "Le_PostHook" "$_post_hook" "base64" ~/.acme.sh/acme.sh: _savedomainconf "Le_RenewHook" "$_renew_hook" "base64" ~/.acme.sh/acme.sh: Le_PostHook="$(_readdomainconf Le_PostHook)" ~/.acme.sh/acme.sh: Le_RenewHook="$(_readdomainconf Le_RenewHook)" ~/.acme.sh/acme.sh: issue "$Le_Webroot" "$Le_Domain" "$Le_Alt" "$Le_Keylength" "$Le_RealCertPath" "$Le_RealKeyPath" "$Le_RealCACertPath" "$Le_ReloadCmd" "$Le_RealFullChainPath" "$Le_PreHook" "$Le_PostHook" "$Le_RenewHook" "$Le_LocalAddress" "$Le_ChallengeAlias"
They are all =’’ EMPTY
I did not expect that.
Where/how did you modify the cron job with the added “--deploy-hook cpanel”?
I didn’t modify the cron job. I didn’t dare touch that thing.
Want me to update it?
I don't think you can add that parameter in there anyway.
Perhaps somehow manually editing each conf file to show:
Le_RenewHook='cpanel'
But that is also a guess.
Maybe you can test one domain file out with that.
I’m perfectly happy to delete that cron job and run this manually every 3 months.
That is hardly a burden.
That is the “default” job; it only tries to renews all certs once a day(as issued) and possibly tries to update itself.
But we know it isn’t updating itself v2.8.6 is not the latest.
So I thought once you updated HOW you got a cert (with the --deploy-hook added) it would “remember” that (for that cert).
But it didn’t store that parameter with that domain … anywhere we could find.
So future renewals will also fail to integrate with cPanel…
But presumably we can keep updating (manually) with --deploy-hook cpanel each time, and that’ll work, correct?
Tedious but yeah
unless there is a “global” command for that
Like:
~/.acme.sh/acme.sh --renew-all --deploy-hook cpanel
[another guess]
You will have to script one line for each cert in your job:
/.acme.sh/acme.sh --renew -d one --deploy-hook cpanel
/.acme.sh/acme.sh --renew -d two --deploy-hook cpanel
/.acme.sh/acme.sh --renew -d twenty --deploy-hook cpanel
[actually not one per domain - one per cert]
Gah!!! So be it. Every 3 months I inch ever closer to this being easy and authoritatively comprehensible, while the process develops new wrinkles I never seem to catch up to.
