The version of my client is : acme.sh v2.8.6
I’ve got an existing set of certs in trillionpictures.com
Trying to add starsandstrife.com.
running the following doesn’t seem to be doing the trick: acme.sh --webroot /path/to/public_html --issue -d starsandstrife.com -d www.starsandstrife.com
That seems to sets itself up as its own independent cert separate from the others, and which, if installed, uninstalls all the others. So ideally instead of ‘–issue’ I’l looking for something more along the lines of ‘–add-to’
I’m not sure that there exists a command to achieve that.
Last time I had to do this, I modified the Le_Alt= line (which contains the list of alternate domains) in the ~/.acme.sh/$DOMAIN/$DOMIAN.conf file, and then forced a renewal.
It sounds like all you need to do is --issue a new cert will ALL the names you want on it.
Then --remove all the certs you no longer need.
[--remove will not actually delete anything (cert&key), it only removes it from the “list” disabling things like --renew-all]
Main_Domain KeyLength SAN_Domains Created Renew born2.run "" www.born2.run,starsandstrife.com,www.starsandstrife.com Wed Sep 16 23:57:51 UTC 2020 Sun Nov 15 23:57:51 UTC 2020 longplay.trillionpictures.com "" www.longplay.trillionpictures.com Sun Aug 30 07:13:05 UTC 2020 Thu Oct 29 07:13:05 UTC 2020 munich72.trillionpictures.com "" www.munich72.trillionpictures.com Sat Aug 1 07:01:52 UTC 2020 Wed Sep 30 07:01:52 UTC 2020 runwithme.trillionpictures.com "" www.runwithme.trillionpictures.com Sat Aug 1 07:02:14 UTC 2020 Wed Sep 30 07:02:14 UTC 2020 sevendeadlysins.trillionpictures.com "" www.sevendeadlysins.trillionpictures.com Sat Aug 1 07:02:27 UTC 2020 Wed Sep 30 07:02:27 UTC 2020 starsandstrife.com "" www.starsandstrife.com Thu Sep 17 00:29:28 UTC 2020 Mon Nov 16 00:29:28 UTC 2020 trillionpictures.com "" www.trillionpictures.com,totallypostal.net,www.totallypostal.net,starsandstrife.com,www.starsandstrife.com,feathercollectionproject.com,www.feathercollectionproject.com,www.born2.run,born2.run,fixitamerica.org,www.fixitamerica.org,keeperofthedream.net,www.keeperofthedream.net,opq-design.com,www.opq-design.com,radical4.media,www.radical4.media,radical4media.com,www.radical4media.com,samself.com,www.samself.com,savingbarbarasizemore.com,www.savingbarbarasizemore.com Sun Aug 30 08:18:16 UTC 2020 Thu Oct 29 08:18:16 UTC 2020 www.trillionpictures.com "" no Sat Aug 1 07:04:38 UTC 2020 Wed Sep 30 07:04:38 UTC 2020
From what I can tell, you can already cover all the names with these certs (and --remove all the rest):
trillionpictures.com Sun Aug 30 08:18:16 UTC 2020 Thu Oct 29 08:18:16 UTC 2020
Those two names already exist in three certs: born2.run starsandstrife.com trillionpictures.com
If I'm understanding correctly, you're saying they have been issued previously and separately. If so, very possible. In the case of starsandstrife, most definitely, on a different account / server which apparently crashed this morning. They've been unable to revive it, so I moved the site over to this shared hosting account.
The problem occurs not when running acme.sh (which shows 'starsandstrife' as included) but when I'm in cPanel > SSL/TLS managing the SSL hosts.
There the starsandstrife is listed but as a certificate not installed. Attempting to install it using 'trillionpicures.com' doesn't work. Attempting to install it using 'starsandstrife' does work, except that in doing so all the certs under trillionpictures that had been working cease working. ??
Does your cPanel support getting the certs by itself?
If you mean can cPanel do the SSL automatically: No.
If you mean can I choose the domain directly and install for that cert? Yes. cPanel suggests it's working, but loading the site in the browser indicates it does not (even after clearing cache etc)
