My web server is (include version): Apache/2.4.37 (rocky)
The operating system my web server runs on is (include version): Rocky Linux 8.8 (Green Obsidian)
My hosting provider, if applicable, is: AWS EC2
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.6.0
I installed this certificate on Apache, and it's been working fine since then. I want to replace Apache with nginx. I don't see any recent topics in this community about how to do that.
Here is the current output from certbot certificates
You don't necessarily need to remove Apache. They can be installed next to each other perfectly fine. It's just you can't run both on the same ports at the same time.
My advice is to configure nginx to your liking while Apache is still running. You could even test nginx out on e.g. HTTP port 8080 while Apache is still running on port 80.
If your nginx is running fine (e.g. on port 8080) you could already install the certificate using the --nginx installer: sudo certbot install --nginx --cert-name hoyo.zeetix.com
You could even temporarily install the certificate on a port different than port 443, which is probably taken by the still running Apache. The command would be then e.g.:
(Not sure if the HTTP to HTTPS redirect would also make sure the redirect is to that specific port though, but if not that would be a bug IMO.)
Then, if nginx is running nicely on ports 8080/80443 and Apache is still running on ports 80/443, you could do, in this order:
modify the nginx configuration and change the port 8080 to 80 (wherever it's mentioned) and port 80443 to 443 (wherever it's mentioned)
stop Apache
(re)start nginx
Note: I have absolutely no clue if your renewal configuration file is also updated by that install command though! Afterwards, you should check the contents of the file /etc/letsencrypt/renewal/hoyo.zeetix.com.conf and see what the value of the installer option is.
OP already has a certificate they can use. No need to re-issue a new one and I'm not sure if a --dry-run (using the staging environment) would help with the migration: I'm not entirely sure it mentions something about the webserver.
