How do I know if Certbot is using the ACMEv2 protocol?
I need to upgrade my Certbot installation to use ACMEv2 instead of ACMEv1. How do I know if this was successful after running: sudo apt update, and then running: sudo apt install --only-upgrade certbot?
Am I missing any steps in upgrading to take advantage of ACMEv2? Thank you in advance!
My domain is: somervillepubliclibrary.org
My hosting provider, if applicable, is: Linode
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.22.2
Hi @hagenah
that's very old. Update your system, not only certbot.
Then check your config files if there is an acme-v01 used. If yes, change that to acme-v02. And check your last log. There you see, what version is used.
Perhaps try
https://certbot.eff.org/docs/using.html
the --server option with the v2-url.
How did you install Certbot?
What was the output of those commands?
Certbot is made up of several packages; upgrading only some of them will cause problems.
Why not run "sudo apt upgrade"?
