How do I contact someone direct, inherited a mess how do we sort out?
Please clarify your question.
Thank you
This is a community support forum, meaning most people here helping are volunteering their time and expertise. Helping to spread the support load across the community is why this works. Please elaborate on the issues you’re encountering, so that the community can assist.
I think we already have an account but obviously no credentials, we have an OVH account referencing a cert from letsencrypt, we have no access to root on ovh, but access to CP and no access to the original cert
I’m thinking of giving up on ovh / letsencrypt and repointing DNS and recreating the site and a proper cert
LE is not limited to only one account per domain
Then you'll just need to follow online directions for create a new cert. (If you followed the steps, there'll be nothing block you from getting a new one)
Thank you
And it's also not limited to one cert per domain (although there are rate limits, there can definitely be several valid certificates for the same names at the same time). So there's really nothing to stop just starting over in this kind of situation.
Let’s Encrypt certificates on OVH shared hosting are managed in their control panel as described here:
https://www.ovh.com/world/g1594.ssl_certificates_on_web_hosting_packages
If your certificate doesn’t appear here or you are unable to issue or renew from the OVH control panel, the issue is likely is on OVH’s side, so please contact their support for assistance.
