I have used this https://github.com/pixielabs/letsencrypt-rails-heroku to setup SSL… I have done everything as said in the url… But SSL not worked in my app. My doubt is how let’s encrypt works with heroku? so can you please explain anybody?
Hi @selva2us
Unfortunately I’m not a Heroku user and don’t have any familiarity with their service or that particular approach to enabling Let’s Encrypt SSL.
Have you tried contacting Heroku support ?
Here is a guide for heroku:
Hi @selva2us, thanks for your note.
We made the gem you’re referring to, and it definitely works with Heroku!
If you have any queries about it, please get in contact with David by filing a query on the Github page.
Thanks,
Pete
