HomeAssistant Duckdns problem connecting to server
I figured that I can't reach my HomeAssistant on the duckdns domain because the duckdns add-on stopped. After starting it I get the following error:
ERROR: Problem connecting to server (get for https://acme-v02.api.letsencrypt.org/directory; curl returned with 6)
EXPECTED value GOT EOF
INFO: Service duckdns exited with code 1 (by signal 0)
Can i somehow fix this?
A curl 6 is usually a problem with your local DNS resolver. I don't know enough about HA or the DuckDNS assistant to say anything more specific than that. If no one else here offers help try the support forum for the DuckDNS assistant for HA. This is likely an environmental setup problem and not related to Let's Encrypt specifically.
