bloomc.us
Within Home Assistant I ran configured the Let's Encrypt add-on with the following values:
domains:
- "*.bloomc.us"
email: oliverwjones@mailfence.com
keyfile: privkey.pem
certfile: fullchain.pem
challenge: dns
dns:
provider: dns-cloudflare
cloudflare_api_token:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/file-structure.sh
cont-init: info: /etc/cont-init.d/file-structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun lets-encrypt (no readiness notification)
s6-rc: info: service legacy-services successfully started
[18:19:13] INFO: Selected DNS Provider: dns-cloudflare
[18:19:13] INFO: Use propagation seconds: 60
[18:19:13] INFO: Use CloudFlare token
Requesting a certificate for *.bloomc.us
Waiting 60 seconds for DNS changes to propagate
Certificate is saved at: /data/letsencrypt/live/bloomc.us/fullchain.pem
Key is saved at: /data/letsencrypt/live/bloomc.us/privkey.pem
This certificate expires on 2023-10-22.
NEXT STEPS:
- The certificate will need to be renewed before it expires. Certbot can automatically renew the certificate in the background, but you may need to take steps to enable that functionality. See User Guide — Certbot 2.6.0 documentation for instructions.
- Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
- Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Home Assistant 2023.7.3
Supervisor 2023.07.1
Frontend 20230705.1 - latest
Debian 12
My DNS provider is Cloudflare.
Yes.
I use Home Assistant's web interface to manage Home Assistant.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): I don't know the answer to this question.
I am trying to get Home Assistant to see my Cloudflare certificate. The output above looks to be successful, but I don't know anymore. I would like to know what else I need to do to get Home Assistant to work correctly. I have my router port forwarding port 8123/TCP to my Home Assistant server.
When I try to go to the home page for Home Assistant from the Internet I get "net::ERR_ADDRESS_UNREACHABLE".
Please let me know what other information you need from me.
Thank you.
Oliver.
