Home assistant and let's encrypt don't work
Hi there, I'm new to this community. I'm trying to switch my home assistant to https but it looks impossible. When I run let's encrypt add-on with http challenge, log say:
Domain: ha.gabrielemattioli.eu
Detail: : Invalid response from http://ha.gabrielemattioli.eu/.well-known/acme-challenge/v25tNi-6LYpCz3HO_7_dIBahUyj_JjNFh1kxGjSvO-4: 404
Furthermore, I opened my 80 port and I redirected request from that port to my local ip of home assistant. When I digit my ip on browser bar, without specifying the port (so port 80) appear this message:
Could anyone help me? Thank you.
Hello @gabriele_m, welcome to the Let's Encrypt community. :slightly_smiling_face:
Let’s Encrypt offers Domain Validation (DV) certificates, not IP Address certificates presently. The screen shot you are showing is using an IP Address and will generate a warning for most web browsers, and correctly so.
Did you stop the web server prior to running Certbot?
As Certbot will require exclusive access to Port 80 for that command.
Using the online tool Let's Debug yields these results https://letsdebug.net/ha.gabrielemattioli.eu/2054526 "OK"
You only have Port 80 Open and Port 443 Filtered (i.e. blocked).
$ nmap -Pn -p80,443 ha.gabrielemattioli.eu
Starting Nmap 7.80 ( https://nmap.org ) at 2024-06-23 19:44 UTC
Nmap scan report for ha.gabrielemattioli.eu (77.240.232.174)
Host is up (0.17s latency).
rDNS record for 77.240.232.174: u-5m-77-240-232.4bone.mynet.it
PORT    STATE    SERVICE
80/tcp  open     http
443/tcp filtered https
Nmap done: 1 IP address (1 host up) scanned in 3.57 seconds
Using this tool Open Port Check Tool - Test Port Forwarding on Your Router
Thanks for your answer, but I still don't know what to do. I'm not trying to certificating an ip adress but my personal domain, so I don't know what to do.
@gabriele_m can you answer the above question?
No, I did not, how can I do that?
@gabriele_m that questions is better suited to the
Home Assistant forum here: https://community.home-assistant.io/
So I just need to shut down home assistant temporally right?
Yes! Prior to running Certbot shut it OFF, after Certbot is done running and successfully retrieved the issued certificate turn it back ON.
Ok, but how can i shut down home assistant without stop certbot? I use home assstant OS on proxmox so I do everything from HA. As I said before I use let's encrypt add on.
Does Home Assistant require the
The webroot authenticator would most likely be easier.
Sorry, I didn't catch, could you explain widely?
Standalone Certbot spins up its own (temporary) server to serve the HTTP-01 Challenge's response and then shuts down, all on Port 80.
While webroot uses the existing running webserver to serve the response.
When I surf to http://ha.gabrielemattioli.eu/, I'm getting a "405 method not allowed" response. Are you running Home Assistant directly on port 80 or are you using some reverse proxy in between?
@Bruce5051 They're not running Certbot themselves, but the HA addon is using it internally..
Hi, are you sure? When I open that I see home assistant login. Yes, I'm running home assistant directly on port 80.
Thank you @Osiris as always! :slight_smile:
I'll sit on the sideline now.
Apparently, HA doesn't like the "HEAD" HTTP method (compared to GET).. With GET it works indeed.
Anyway, I don't know why the HA addon doesn't work.. How did you configure it?
Aha, using the GUI.
I believe your DNS provider is GoDaddy, right? That's unfortunate, as GoDaddy recently restricted usage of their DNS API to users with certain perks/money spend et c. Most users don't have API access any longer. So you're probably stuck with using the http-01 challenge you're currently using.
I don't understand why your HA addon is resulting in a 404 though. There's really not much to configure, the addon should do all the work.
Maybe one of the support channels of the addon listed at addons/letsencrypt/DOCS.md at master · home-assistant/addons · GitHub might know?
Should I try with dns challenge instead?
That would require the DNS be hosted not at GoDaddy.
