Help with Domain name does not end with a valid public suffix (TLD)
My domain is: vhaan.me and mail.vhaan.me
I ran this command: sudo certbot
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: vhaan.me.tld
2: mail.vhaan.me.tld
Requesting a certificate for vhaan.me.tld and mail.vhaan.me.tld
An unexpected error occurred:
Invalid identifiers requested :: Cannot issue for "mail.vhaan.me.tld": Domain name does not end with a valid public suffix (TLD) (and 1 more problems. Refer to sub-problems for more information.)
My web server is (include version): - Server version: Apache/2.4.61
The operating system my web server runs on is (include version): - Name: Debian GNU/Linux
  • Pretty Name: Debian GNU/Linux 12 (bookworm)
  • Version: 12 (bookworm)
  • Version ID: 12
  • Codename: bookworm
I can login to a root shell on my machine (yes or no, or I don't know): i dont know
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.11.0
I also installed certbot with: sudo snap install --classic certbot
Hello @lemirq,
Let’s Encrypt offers Domain Validation (DV) certificates.
Domain names for issued certificates are all made public in Certificate Transparency logs(e.g. crt.sh | example.com), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
Thus you need to own and have control over the Domain Name (or have a subdomain under an existing domain name, for example pointed to your server by your employer or school) you wish to obtain a certificate for, from an ICANN Accredited Registrar.
Please mind I'm a beginner with linux. The thing is, I'm trying to setup an email server with a raspberry pi following this tutorial: https://www.makeuseof.com/make-your-own-raspberry-pi-email-server/. It requires me to use certbot for my domains.
But you will need a domain name that does end with a public suffix (TLD) to obtain a certificate issued by Let’s Encrypt. Presently Let’s Encrypt does not issue certificates for IP Addresses.
Did you misspell your domain name in Apache config?
Because you say the name ends in .me but Certbot saw the Apache config had it with .me.tld
Sorry but could you please explain what a public suffix is? I am not very experienced and got my domain from namecheap.
Oh really? The tutorial I followed told me to write ServerName mail.vhaan.me.tld in my config files
Public Suffix List - Wikipedia
I was just trying to use words you had used in the topic’s Title, assuming you knew what is.
Sorry, but this is not really helping
I own vhaan.me already, so what seems to be the problem?
That looks like a fine valid domain name to me.
I think you misunderstood what they meant. You should use your actual domain name
Or, it is really bad instruction in which case quit using it :slight_smile:
Here is what Let’s Debug is showing https://letsdebug.net/vhaan.me/2174093
MultipleIPAddressDiscrepancy
WARNING
vhaan.me has multiple IP addresses in its DNS records. While they appear to be accessible on the network, we have detected that they produce differing results when sent an ACME HTTP validation request. This may indicate that some of the IP addresses may unintentionally point to different servers, which would cause validation to fail.
[Address=70.50.92.209,Address Type=IPv4,Server=Apache/2.4.61 (Debian),HTTP Status=404] vs [Address=76.76.21.21,Address Type=IPv4,Server=Vercel,HTTP Status=404]
So it's a problem because I am currently hosting a site on vercel??
Not necessarily, but you do have more than one IP Address and they are not all responding the same.
Here is what your DNS looks like.
Wow thanks a lot. So what IP should I remove? the one ending in 209 is the raspberry pi, and the one ending in 21 is for vercel.
Another update: I switched from previously configured .tld to my proper vhaan.me domain. And ran sudo certbot again:
Requesting a certificate for vhaan.me and mail.vhaan.me
Domain: vhaan.me
Detail: 76.76.21.21: Invalid response from http://vhaan.me/.well-known/acme-challenge/qzgTMmr9S107juHnUrBdRvn6BluFD4fQX7tl5ZvTEhg: 404
Remove the one that doesn’t equal the output of the following commands.
curl -4 ifconfig.me
curl -4 ifconfig.io
But then my site wouldn't be hosted with vercel right?
