Help with certificate renewal
My domain is: malamut.es
I ran this command: ./certbot-auto renew
Processing /etc/letsencrypt/renewal/malamut.es.conf
Attempting to renew cert (malamut.es) from /etc/letsencrypt/renewal/malamut.es.conf produced an unexpected error: urn:acme:error:rateLimited :: There were too many requests of a given type :: Error creating new authz :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/. Skipping.
/etc/letsencrypt/live/malamut.es/fullchain.pem (failure)
My web server is (include version): Apache version 2.2.15
CentOS 6
This error just indicates that you’ve been experiencing a lot of errors recently.
Try
./certbot-auto renew --dry-run
to get a meaningful error, and then post back with that, along with the contents of /etc/letsencrypt/renewal/malamut.es.conf .
after running --dry-run i got this:
http-01 challenge for malamut.es
Waiting for verification…
new certificate deployed with reload of apache server; fullchain is
/etc/letsencrypt/live/malamut.es/fullchain.pem (success)
the contents of /etc/letsencrypt/renewal/malamut.es.conf are:
renew_before_expiry = 30 days
version = 0.22.2
cert = /etc/letsencrypt/live/malamut.es/cert.pem
privkey = /etc/letsencrypt/live/malamut.es/privkey.pem
chain = /etc/letsencrypt/live/malamut.es/chain.pem
fullchain = /etc/letsencrypt/live/malamut.es/fullchain.pem
archive_dir = /etc/letsencrypt/archive/malamut.es
[renewalparams]
authenticator = apache
installer = apache
account = 96ea11448018ab34e15e22f81797da6d
That’s strange. It should succeed.
Do you have any other domains on that server being managed by Certbot? If they were failing, they could have “eaten up” the failed authorization rate limit before malamut.es had a chance to run.
ls -l /etc/letsencrypt/renewal/
thanks for the reply, there’s no other domain on the server, just malamut.es
total 4
-rw-r–r--. 1 elmaxx elmaxx 453 Mar 22 22:52 malamut.es.conf
Wait out the rate limit window (60 minutes) and try again without --dry-run. If you still get an error (and it isn’t the rateLimited error), post back.
Alternatively if you can find the right log file in /var/log/letsencrypt/ before the rate limits occurred, that would also reveal the issue.
Do you have a cron job setup for certbot-auto? What does it look like?
I don’t have a cron job (anymore), i do get an email reminder to renew, which i prefer to do manually
thanks, i’ll wait it out a bit before trying renew again, i’ll post the error along with the log file
thank you so much for taking the time to help me with this
This is the error for renew
tls-sni-01 challenge for malamut.es
Attempting to renew cert (malamut.es) from /etc/letsencrypt/renewal/malamut.es.conf produced an unexpected error: Failed authorization procedure. malamut.es (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested 1e0d08e268fdd842630c71397284485c.04c0ed968224109d7dd6f3131bcfbc7d.acme.invalid from 209.153.127.192:443. Received 2 certificate(s), first certificate had names “malamut.es”. Skipping.
    Domain: malamut.es
    Detail: Incorrect validation certificate for tls-sni-01 challenge.
    Requested
    This is the pastebin link for the log file : https://pastebin.com/PrufuPhW
Thanks so much for your time
You are using sni-01-challenge.
Do you know this:
Isn't it possible to switch to http-01 or dns-01 - challenge?
Hi, thanks for your reply, the recommended step there is to use certbot-auto which i have.
Hi @elmaxx,
Force renew to use http challenge:
./certbot-auto renew --preferred-challenges http
Cheers,
sahsanu
you are a true gentleman and scholar
thanks a bunch!
