I have a problem with a let’s encrypt certificate.
I want to uninstall the certificate but i dont know how and the thing is that I also dont know when, who and how a let’s encrypt certificate was installed in my site. I think my last programer that he doesnt work with me anymore, installed the certificate, but i really don’t know and I can’t talk with him.
I don't use GoDaddy. But if you use a shared hosting solution, then there should be an option to remove one certificate and upload another certificate.
So GoDaddy should be able to tell you how to do this. It's their shared hosting, so they know the details of your setup.
They tell me they can not see where the certificate is installed. Maybe because the certificate was not installed from the hosting, but from somewhere else.
Maybe through FTP or from the backend of the site in some way.
If you are not sure whether or not your system has this already automated, refer to your distribution’s documentation, or check your system’s crontab (typically in /etc/crontab/ and /etc/cron.*/* and systemd timers ( systemctl list-timers ).
If you can deactivate this renew job, you can ignore the certificate. Then install the new certificate, so the Letsencrypt certificate is replaced.
