Help Renewing Wildcard Cert
My domain is: *.clearpath.site
I ran this command: sudo certbot renew -v
Processing /etc/letsencrypt/renewal/clearpath.site-0001.conf
Certificate is due for renewal, auto-renewing...
Plugins selected: Authenticator dns-linode, Installer apache
Renewing an existing certificate for clearpath.site and *.clearpath.site
dns-01 challenge for clearpath.site
Unsafe permissions on credentials configuration file: /home/david/.secrets/certbot/linode.ini
Encountered exception during recovery: ValueError: invalid literal for int() with base 10: '[]'
Failed to renew certificate clearpath.site-0001 with error: invalid literal for int() with base 10: '[]'
Processing /etc/letsencrypt/renewal/clearpath.site.conf
Renewal configuration file /etc/letsencrypt/renewal/clearpath.site.conf is broken.
The error was: expected /etc/letsencrypt/live/clearpath.site/cert.pem to be a symlink
Skipping.
  /etc/letsencrypt/live/clearpath.site-0001/fullchain.pem (failure)
Additionally, the following renewal configurations were invalid:
  /etc/letsencrypt/renewal/clearpath.site.conf (parsefail)
1 renew failure(s), 1 parse failure(s)
The operating system my web server runs on is (include version): Ubuntu 20.10
My hosting provider, if applicable, is: Linode
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.17.0
Welcome Back to the Let's Encrypt Community, David :slightly_smiling_face:
Let's get to the bottom of this. :gloves:
What are the outputs of:
sudo certbot certificates
sudo ls -lRa /etc/letsencrypt
sudo apachectl -S
sudo ls -lRa /etc/apache2/sites-available
sudo ls -lRa /etc/apache2/sites-enabled
Please put 3 backticks above and below each output, like this:
output
Thanks for the fast response!
sudo certbot certifictaes
Renewal configuration file /etc/letsencrypt/renewal/clearpath.site.conf produced an unexpected error: expected /etc/letsencrypt/live/clearpath.site/cert.pem to be a symlink. Skipping.
Found the following certs:
  Certificate Name: clearpath.site-0001
    Serial Number: 3f6ef929eaf84da10e31b2b3abcc4fd5dd8
    Key Type: RSA
    Domains: clearpath.site *.clearpath.site
    Expiry Date: 2021-07-06 19:45:16+00:00 (INVALID: EXPIRED)
    Certificate Path: /etc/letsencrypt/live/clearpath.site-0001/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/clearpath.site-0001/privkey.pem
The following renewal configurations were invalid:
sudo apachectl -S
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 173.230.154.79. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:443                  clearpath.site (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80                   clearpath.site (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: "/etc/apache2"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
/etc/apache2/sites-available:
total 20
drwxr-xr-x 2 root root 4096 Jun 22 06:46 .
drwxr-xr-x 8 root root 4096 Jul  6 21:56 ..
-rw-r--r-- 1 root root 2601 Apr  7 20:48 000-default-le-ssl.conf
-rw-r--r-- 1 root root 1666 Apr  7 20:54 000-default.conf
-rw-r--r-- 1 root root 2549 Apr  7 20:51 000-default.conf.save
/etc/apache2/sites-enabled:
total 8
drwxr-xr-x 2 root root 4096 Jun  5 15:44 .
lrwxrwxrwx 1 root root   52 Jun  5 15:44 000-default-le-ssl.conf -> /etc/apache2/sites-available/000-default-le-ssl.conf
lrwxrwxrwx 1 root root   35 Jun  5 15:44 000-default.conf -> ../sites-available/000-default.conf
I skipped the sudo ls -lRa /etc/letsencrypt as it was causing my terminal to freak out when I tried to copy it. Please lmk if it is necessary still.
Thanks for those. :slightly_smiling_face:
I do need the last bit.
This should be easier:
sudo ls -lRa /etc/letsencrypt > output.txt
Then just upload output.txt with the button in your next post.
Sweet. Here we go!
output.txt (23.1 KB)
Someone has a really smart computer... [one that knows what you meant and did that instead]
OR
There has been a little bit of manual reconstruction.
This is also concerning:
One moment. Processing... :grin:
I have an international meeting right now. Back as soon as I can. I see the problems and am fairly confident we can sort this without much trouble.
In the meantime, what are the outputs of:
sudo cat /etc/apache2/sites-available/000-default.conf
sudo cat /etc/apache2/sites-available/000-default-le-ssl.conf
sudo cat /etc/apache2/sites-available/000-default.conf.save
sudo cat /etc/letsencrypt/renewal/clearpath.site.conf
sudo cat /etc/letsencrypt/renewal/clearpath.site-0001.conf
In the (meaningless) meantime...
Can we have a look at these two files?:
/etc/letsencrypt/renewal:
total 16
drwxr-xr-x 9 root root 4096 Jul  6 22:13 ..
-rw-r--r-- 1 root root  660 Apr  7 20:45 clearpath.site-0001.conf
-rw-r--r-- 1 root root  581 Apr  7 20:14 clearpath.site.conf
<VirtualHost *:80>
        ServerName clearpath.site
        ServerAlias *.clearpath.site
        DocumentRoot /var/www/html
RewriteEngine On
RewriteRule ^\.well-known\/acme-challenge\/ - [L]
RewriteCond %{HTTPS} !=on
RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1 [R,L]
</VirtualHost>
<IfModule mod_ssl.c>
<VirtualHost *:443>
        ServerAlias www.clearpath.site
        Alias /static /home/david/clearpath_project/static
        DocumentRoot /home/david/clearpath_project
        <Directory /home/david/clearpath_project/static>
                Require all granted
        </Directory>
        Alias /media /home/david/clearpath_project/media
        <Directory /home/david/clearpath_project/media>
                Require all granted
        </Directory>
        <Directory /home/david/clearpath_project/config>
                <Files wsgi.py>
                        Require all granted
                </Files>
        </Directory>
        WSGIScriptAlias / /home/david/clearpath_project/config/wsgi.py
        WSGIDaemonProcess clearpath python-path=/home/david/clearpath_project python-home=/home/david/clearpath_project/venv
        WSGIProcessGroup clearpath
        WSGIPassAuthorization On
SSLCertificateFile /etc/letsencrypt/live/clearpath.site-0001/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/clearpath.site-0001/privkey.pem
</VirtualHost>
</IfModule>
<VirtualHost *:80>
                Require all granted
        </Directory>
                Require all granted
        </Directory>
                <Files wsgi.py>
                        Require all granted
                </Files>
        </Directory>
       # WSGIDaemonProcess clearpath python-path=/home/david/clearpath_project python-home=/home/david/clearpath_project/venv
RewriteEngine on
RewriteCond %{SERVER_NAME} =clearpath.site [OR]
RewriteCond %{SERVER_NAME} =www.clearpath.site
</VirtualHost>
version = 0.36.0
archive_dir = /etc/letsencrypt/archive/clearpath.site
cert = /etc/letsencrypt/live/clearpath.site/cert.pem
privkey = /etc/letsencrypt/live/clearpath.site/privkey.pem
chain = /etc/letsencrypt/live/clearpath.site/chain.pem
fullchain = /etc/letsencrypt/live/clearpath.site/fullchain.pem
[renewalparams]
account = 0db7788607bca1bcf498638309c036ed
authenticator = dns-linode
installer = apache
dns_linode_credentials = /home/david/linode.ini
version = 1.14.0
archive_dir = /etc/letsencrypt/archive/clearpath.site-0001
cert = /etc/letsencrypt/live/clearpath.site-0001/cert.pem
privkey = /etc/letsencrypt/live/clearpath.site-0001/privkey.pem
chain = /etc/letsencrypt/live/clearpath.site-0001/chain.pem
fullchain = /etc/letsencrypt/live/clearpath.site-0001/fullchain.pem
[renewalparams]
installer = apache
dns_linode_propagation_seconds = 120
dns_linode_credentials = /home/david/.secrets/certbot/linode.ini
Fwiw I have some old notes from the installation process I initially went through:
certbot \
  --dns-linode \
  --dns-linode-credentials ~/linode.ini \
  -i apache \
  -d clearpath.site \
  -d *.clearpath.site
Created an SSL vhost at /etc/apache2/sites-available/000-default-le-ssl.conf
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Deploying Certificate to VirtualHost /etc/apache2/sites-available/000-default-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/000-default-le-ssl.conf
No vhost exists with servername or alias for domain *.clearpath.site. No vhost was selected. Please specify ServerName or ServerAlias in the Apache config.
No vhost selected
 - Unable to install the certificate
   Your cert will expire on 2020-03-17. To obtain a new or tweaked
   with the "certonly" option. To non-interactively renew *all* of
david@clearpath:~$ sudo certbot certificates
    Expiry Date: 2020-03-17 19:43:26+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/clearpath.site/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/clearpath.site/privkey.pem
david@clearpath:~$ sudo certbot --reinstall -d clearpath.site -d *.clearpath.site
Cert not yet due for renewal
Which VirtualHosts would you like to install the wildcard certificate for?
1: File: /etc/apache2/sites-available/000-default-le-ssl.conf
Addresses: *:443
Names: clearpath.site, *.clearpath.site
HTTPS: Yes
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Enabled Apache rewrite module
Redirecting vhost in /etc/apache2/sites-enabled/000-default.conf to ssl vhost in /etc/apache2/sites-available/000-default-le-ssl.conf
Congratulations! You have successfully enabled https://clearpath.site and
https://*.clearpath.site
https://www.ssllabs.com/ssltest/analyze.html?d=clearpath.site
https://www.ssllabs.com/ssltest/analyze.html?d=*.clearpath.site
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
IIRC I had to comment out the WSGI lines in the conf files before installing the cert. Is this correct?
Yeah, so the reinstall didn't actually work because now I have SSL on the main domain but every subdomain gives me an Ubuntu error page.
Noticeable differences:
Probably due to lack of wildcard support (in the web server configuration):
[that "www" should probably be "*" (an asterisk)]
I take it back. Now my main domain is 403 forbidden and the subdomains are all Ubuntu Apache error pages. Man, I think I messed this up..
So this is what I have done... I added a new linode API key to the linode.ini file and tried to reinstall it.
The error I get is:
sudo certbot --reinstall -d clearpath.site -d *.clearpath.sitee logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
Saving debug log to /var/log/letsencrypt/letsencrypt.loge/000-default-le-ssl.conf
Deploying certificate
Successfully deployed certificate for clearpath.site to /etc/apache2/sites-enabled/000-default-le-ssl.conf
1: File: /etc/apache2/sites-enabled/000-default-le-ssl.conf
Addresses: *:443
Names: www.clearpath.site, clearpath.site
HTTPS: Yes
2: File: /etc/apache2/sites-enabled/000-default.conf
Addresses: *:80
Names: *.clearpath.site, clearpath.site
HTTPS: No
Some rewrite rules copied from /etc/apache2/sites-enabled/000-default.conf were disabled in the vhost for your HTTPS site located at /etc/apache2/sites-available/000-default-le-ssl.conf because they have the potential to create redirection loops.
Could not install certificate
An unexpected error occurred:
augeas.AugeasValueError: Augeas.set() failed: Too many matches for path expression
What should I do from here?
Break out of that (c to cancel) and modify the file:
Change the line:
To:
[then restart Apache and rerun certbot]
and let's reconfirm which files are being used with:
sudo apachectl -S
