Help Renewing Wildcard Cert
Okay. I changed the www to the wildcard and then restarted Apache and the whole site and SSL certs are working again (without rerunning certbot).
Then:
sudo apachectl -S
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 173.230.154.79. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:443                  clearpath.site (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80                   clearpath.site (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: "/etc/apache2"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
OK that is what I expected :slight_smile:
Anything missing?
What says?:
certbot certificates
Thanks for all the help!
sudo certbot certificates
Renewal configuration file /etc/letsencrypt/renewal/clearpath.site.conf produced an unexpected error: expected /etc/letsencrypt/live/clearpath.site/cert.pem to be a symlink. Skipping.
Found the following certs:
  Certificate Name: clearpath.site-0001
    Serial Number: 3f1e45713be97e1d1a7df5e057841350b36
    Key Type: RSA
    Domains: clearpath.site *.clearpath.site
    Expiry Date: 2021-10-04 23:59:50+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/clearpath.site-0001/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/clearpath.site-0001/privkey.pem
The following renewal configurations were invalid:
Is there an easy way to turn on auto-renew for wildcards?
When (like in your case) you don't use --manual, then YES.
It can be renewed like normal.
With a cron job, or systemd timer, that (twice a day) runs: certbot renew
[please avoid running at the top of any hour - preferably use some added randomized time offset]
Actually, please check to see if one has already been created.
Yeah I will look around for one. Mainly asked to get an idea of what terms to search :slight_smile: thanks for everything!
For root user:
crontab -l
And, since you are using Ubuntu, also check:
systemctl list-timers | grep certbot
[remember to mark one of these (many) replies as a solution to this topic]
Looks like things progressed. :smiley:
This is still annoying me:
Yep. That's a problem.
Did you fix the live symlinks (or lack thereof) for the clearpath.site certificate?
No, I was kinda hoping the renewal would fix things - but it hasn't.
[Your turn]
It looks like the clearpath.site certificate vanished!?
I didn't see a delete command listed anywhere.
Nope. It got skipped due to broken symlinks.
@5starkarma
  1. Remove the cruft.
sudo a2dissite 000-default.conf
sudo a2dissite 000-default-le-ssl.conf
sudo rm /etc/apache2/sites-available/000-default.conf
sudo rm /etc/apache2/sites-available/000-default-le-ssl.conf
sudo rm /etc/apache2/sites-available/000-default.conf.save
sudo certbot delete --cert-name clearpath.site
sudo certbot delete --cert-name clearpath.site-0001
  1. Install the correct configuration file.
Download clearpath.site.conf.txt (973 Bytes)
Put it in /etc/apache2/sites-available
sudo mv /etc/apache2/sites-available/clearpath.site.conf.txt /etc/apache2/sites-available/clearpath.site.conf
sudo a2ensite clearpath.site.conf
  1. Reload Apache.
sudo apachectl -k graceful
  1. Acquire and install the correct certificate.
sudo certbot -a dns-linode --dns-linode-credentials /home/david/.secrets/certbot/linode.ini --dns-linode-propagation-seconds 120 -d "clearpath.site,*.clearpath.site" -i apache
