Help Renewing certificate
acme.sh --force
nginx
Netcup
no
Hello All And thank you for your help in advance
I am an amateur so please forgive me for my lack of knowledge
I am using lets encrypt certificate and everything is working well, the renewal of the certificate is successful and then I reload nginx to serve the new certificates I also checked at crt.sh
but when looking at the browser (Firefox and safari) it tells the certificate will expire on august 12, and it is not the renewal date
Again I m sorry for this type of question if anyone can please help
Again Thank you
Gilad
The use of --force is usually more harmful than helpful.
Please show:
acme.sh list
Have a look at:
SSL Server Test: chat.giladsky.com (Powered by Qualys SSL Labs)
Clear your browsers cache and retry the site.
Hello @rg305
Thank you for your prompt response
I used --force only this this time because I tried to resolve before contacting here
I tried clear clearing browsers cache and the same thing happened
the out put for acme.sh list
Main_Domain KeyLength SAN_Domains CA Created Renew
chat.giladsky.com "4096" no LetsEncrypt.org Mon 02 Aug 2021 03:52:12 AM UTC Fri 01 Oct 2021 03:52:12 AM UTC
chat.giladsky.com "ec-384" no LetsEncrypt.org Mon 02 Aug 2021 03:55:43 AM UTC Fri 01 Oct 2021 03:55:43 AM UTC
Again thank you
It's unfortunate that you didn't specify the output of the command earlier. It could have been the most helpful information.
On the acme.sh github page I also read stuff like acme.sh --renew so you might want to try that commannd and please post the output of the command here.
So there are two valid certs (ec-384 & RSA 4096) available for your use.
There is no need to get another one.
The next step is to understand how the "Jitsi Meet" system uses certs.
Then follow those steps to secure it.
Depending on those steps, you may be able to automate the entire renewal/update process.
Feel free to ask questions on those parts once you have more detail on them.
