Help, please! I cannot get certificate for Zimbra
Hello, I try to renew certificate for my Zimbra (7 ver) mail server (mail.benta.spb.ru), but letsencrypt-auto say that problem with authorization. I try some times and now it say that too many times with bad authorization and I cannot renew my certificate! Oh! All mail in our company is stopped… =( Where I can take off block?
3 month ago I normally renew my certificate, but now error with some authorization. Where I can to fix it?
I want ask:
  1. How long I am blocking?
  2. What th e problem with authorization?
    I have so message from log of letsencrypt:
[root@mail letsencrypt]# ./letsencrypt-auto renew
Processing /etc/letsencrypt/renewal/mail.benta.spb.ru.conf
http-01 challenge for mail.benta.spb.ru
Waiting for verification…
Attempting to renew cert (mail.benta.spb.ru) from /etc/letsencrypt/renewal/mail.benta.spb.ru.conf produced an unexpected error: Failed authorization procedure. mail.benta.spb.ru (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://mail.benta.spb.ru/.well-known/acme-challenge/9-sLvAJ3qR-Qg0XWzDdWylqGvdLv1BiBogge8J9ci7s: Timeout during connect (likely firewall problem). Skipping.
/etc/letsencrypt/live/mail.benta.spb.ru/fullchain.pem (failure)
    Domain: mail.benta.spb.ru
    Type: connection
    Detail: Fetching
What I can doing that authorizating will pass?
Whith best regards, Raulina.
Hello @Raulinka,
There is a Failed Validation limit of 5 failures per account, per hostname, per hour, so 1 hour.
Lets Encrypt can't reach your site to validate the challenge... me too.
$ curl -v4IkL -m 10 http://mail.benta.spb.ru/.well-known/acme-challenge/9-sLvAJ3qR-Qg0XWzDdWylqGvdLv1BiBogge8J9ci7s
*   Trying 195.182.147.38...
* TCP_NODELAY set
* Connection timed out after 10000 milliseconds
* Curl_http_done: called premature == 1
* stopped the pause stream!
* Closing connection 0
curl: (28) Connection timed out after 10000 milliseconds
You should double check there is no firewall rules blocking the connection, that your web server is up and running...
Cheers,
sahsanu
Hi @Raulinka
checking your connections:
• http://mail.benta.spb.ru/ -14 10.030 T
Timeout - The operation has timed out
• http://www.mail.benta.spb.ru/ -1 0.043 U
NameResolutionFailure - The remote name could not be resolved: 'www.mail.benta.spb.ru'
• https://mail.benta.spb.ru/ -2 1.117 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 195.182.147.38:443
• http://mail.benta.spb.ru/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de -14 10.026 T
The timeout is normal because you use the standalone option. So Certbot creates a new webserver, starts and stops it. So we can't check your permanent running webserver.
But: Your port 443 is blocked.
So it looks that your colleagues had added a firewall or something else in the last three months.
PS: Your certificate ends Sunday:
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:mail.benta.spb.ru&lu=cert_search
So you want to renew it today. Do you have access to your dns entries? If yes, you can use
sudo certbot certonly --manual --preferred-challenges dns -d mail.benta.spb.ru
and create a dns txt entry
_acme-challenge.mail.benta.spb.ru
with the value certbot creates.
Dear JuergenAuer! Thank you for answer.
Can you check my server again? I stopped Apache, maybe server not working for that? Now I restart all and ask you, please try check connection again.
I want to renew certificate today, but my sudo writting: “sudo: certbot: command not found”. I havn’t certbot or anything yet?
With best regards, Raulina
@Raulinka,
All the connections timeout, I tried port 80, port 443, port 25 ... are you sure there isn't a firewall blocking the connections or a misconfigured router?.
As @JuergenAuer said, you are using standalone method to validate the lets encrypt challenge, that means that your client (letsencrypt-auto) will start a simple web server on port 80 to serve the challenge and validate that you control your domain. If there is another web server listening on port 80, letsencrypt-auto client can't bind to port 80 but you would receive a different error.
You should not use certbot, you should use letsencrypt-auto, that is the name of your client (at least you said that on your first post).
As I said previously, you should double check that you can access to your server from internet.
Cheers,
sahsanu
Certbot = certbot-auto = letsencrypt-auto.
The program is the same, the output is the same. So if I write certbot, use your ./letsencrypt-auto.
• http://mail.benta.spb.ru/ -14 10.034 T
• http://www.mail.benta.spb.ru/ -1 0.046 U
• https://mail.benta.spb.ru/ 200 5.934 N
Certificate error: RemoteCertificateChainErrors
• http://mail.benta.spb.ru/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de -14 10.027 T
Now it's better, your https is working. But your http has a timeout again. Can you create / start a http webserver?
Please have a look at: https://wiki.zimbra.com/wiki/Installing_a_LetsEncrypt_SSL_Certificate
Hello, dear @JuergenAuer and @sahsanu!
Thank you very much for help to me!
I disabled suricata, adding new rule to NAT on firewall, where I passing 80 port and http protocol, but not any changes in answer from script.
After I remember that we adding new sftp-server to DNS resolver. This is one rule, that was added for last 3 month. I removing this rule and my letsencrypt-auto earned!
I am happy!!! =) Thank you, dear friends!!! I love you!
