hi i need help on the challenge like on challenge num 2 where you enter a webroot but idk what is a webroot or what. Im only a beginner and im useing IIS. Please tell me the steps for doing the challange. Thanks.
For IIS I highly recommend using an ACME client designed for Windows. I think the most popular is Certify The Web which has a friendly gui. They also have an excellent support forum of their own
ok i will try thanks
