I am running a wordpress site on lightsail. I successfully installed the a letsencrypt certificate on the site 90 days ago. It expired. I re ran the same scripts located here (the lego version, second half of the site).
https://docs.bitnami.com/aws/how-to/generate-install-lets-encrypt-ssl/
It says that certificate was successfully installed and I can see it in the directory. I copy it to apache server site and restart the server. Wordpess works, the site works, but the certificate is expired. I have tried everything. Can some let me know if there is a consultant I can hire to just set this up correctly? Its been four hours and Its at that point… All i need is for someone to log in, install it and verify that it works.
My domain is: bounte.net
My web server is (include version): ubuntu
My hosting provider, if applicable, is: AWS / . Lightsail
