There were too many requests of a given type :: Error finalizing order :: too many certific ates already issued for exact set of domains:t
My domain is: marektinglab.biz
I ran this command: sudo nano /opt/bitnami/apps/wordpress/htdocs/wp-config.php
SSLCertificateFile “/etc/letsencrypt/live/marketinglab.biz/cert.pem”
SSLCertificateKeyFile “/etc/letsencrypt/live/marketinglab.biz/privkey.pem”
SSLCertificateChainFile “/etc/letsencrypt/live/marketinglab.biz/fullchain.pem”
It produced this output: Website down. HTTP ERROR 500
My web server is (include version): Not sure
The operating system my web server runs on is (include version): Ubuntu 16.04.4 LTS (GNU/Linux 4.4.0-1060-aws x86_64)
My hosting provider, if applicable, is: Lightsail
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): No. I’m using Lightsail
What’s the issues here?
Thank you
I was learning how to install Letsencrypt on Lightsail. Tried a few times until I hit the cert limit. Didn’t get the cert and now my site is down. :frowning:
As of now… Do you still have the original certificate?
If not, you might need to find a way to bypass the “exact set” restrictions. Else, you’ll need to wait for 7 days (or less) before retry.
Also, could you start your webserver?
Error 500 is a photo error, not a web server related one.
Thank you
Thanks.
I can start my webserver. After I enter:
SSLCertificateFile "/etc/letsencrypt/live/marketinglab.biz/cert.pem"
SSLCertificateKeyFile "/etc/letsencrypt/live/marketinglab.biz/privkey.pem"
SSLCertificateChainFile "/etc/letsencrypt/live/marketinglab.biz/fullchain.pem"
on wp-config, my website is not working.
Here’s the cert I have.
Huh? Your SSL configuration does not belong in wp-config.php.
You probably broke your WordPress installation by doing that. Undo it.
Oh no…
What is the command that I should use to install
That goes in your Apache configuration.
grep -iR sslcertificatefile /etc/apache2
Thanks. It says no such file
Well, wherever your Apache configuration files are on your Lightsail server, that’s what you’ll need to update.
It might be somewhere in /opt/bitnami. Check the Bitnami docs for SSL.
Thanks a lot. Let me try it out later.
I tried running ./certbot-auto certonly marketinglab.biz but can’t retrieve the cert. Not sure what’s wrong.
Requesting to rerun ./certbot-auto with root privileges…
usage:
certbot-auto [SUBCOMMAND] [options] [-d DOMAIN] [-d DOMAIN] …
Certbot can obtain and install HTTPS/TLS/SSL certificates. By default,
it will attempt to use a webserver both for obtaining and installing the
certificate.
certbot: error: unrecognized arguments: marketinglab.biz
The command should be ./certbot-auto certonly -d marketinglab.biz (-d before each domains)
Thank you
Thanks a lot. But still can't find the directory. Wonder what has went wrong.
bitnami@ip-172-26-11-137:~$ ./certbot-auto certonly -d marketinglab.biz
-bash: ./certbot-auto: No such file or directory
bitnami@ip-172-26-11-137:~$ ./certbot-auto certonly -d www.marketinglab.biz
The ./ notation means to execute from the current directory. You have to be in the same directory as certbot-auto for that to work.
Haiz… I’m actually quite lost. Is there any way that I can delete everything and restart the process again? Seems like I have done something wrong somewhere. Fixing it will be more time consuming.
Here’s a snapshot of the SLL cert info which I can’t configure correctly.
I notice the SSL that I installed is under example.com. I don’t know how to remove these. Anyone can help?
Hi @calvinongstudio
your domain https://marketinglab.biz/ uses a self signed certificate, named "example.com", not a certificate with the domain name marketinglab.biz.
Thanks for pointing.
How can I reverse/ delete or reinstall it? When I try to reinstall it, it says I hit the certificate limit.
You have a lot of certificates, see your own post:
And you have files:
So use them in your Apache - configuration. See
https://httpd.apache.org/docs/2.4/ssl/ssl_howto.html
Listen 443
<VirtualHost *:443>
    ServerName www.example.com
    SSLEngine on
    SSLCertificateFile "/path/to/www.example.com.cert"
    SSLCertificateKeyFile "/path/to/www.example.com.key"
</VirtualHost>
