My domain is: www.aspire-network.com
I ran this command: ./certbot-auto --nginx -d www.aspire-network.com -d aspire-netwo rk.com ///// "2"
It produced this output: Cannot find a VirtualHost matching domain www.aspire-network.com
My web server is (include version): CentOS 6
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Wordpress to manage site content
I have been trying to learn about SSL but I'm very much a novice, and I think I've made a big mess. Someone help?
At the moment, I can't get certbot-auto to recognize my domain name. My first install mistakenly only addressed one domain name (aspire-network.com without the WWW), so it gave security warnings. I apparently made a new certificate for the www version without the first domain, which made two separate certificates that were unassociated (problems!). So I finally revoked both so I could start fresh. But now cert-bot can't find my domain at all! Please help.
Here is the terminal response: (notice how it recognizes the previous certificates)
[root@vultr ~]# ./certbot-auto --nginx -d www.aspire-network.com -d aspire-netwo rk.com
/root/.local/share/letsencrypt/lib/python2.6/site-packages/cryptography/init .py:26: DeprecationWarning: Python 2.6 is no longer supported by the Python core team, please upgrade your Python. A future version of cryptography will drop su pport for Python 2.6
DeprecationWarning
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificat e name you requested and isn't close to expiry.
(ref: /etc/letsencrypt/renewal/www.aspire-network.com-0001.conf)
What would you like to do?
2: Renew & replace the cert (limit ~5 per 7 days)Select the appropriate number [1-2] then [enter] (press 'c' to cancel): 2
tls-sni-01 challenge for www.aspire-network.com
tls-sni-01 challenge for aspire-network.com
Cannot find a VirtualHost matching domain www.aspire-network.com.
Here's the https.conf for wordpress (in the nginx directory):
upstream php-handler-https {
server 127.0.0.1:9000;
#server unix:/var/run/php5-fpm.sock;
listen 443 ssl default_server;
server_name www.aspire-network.com, aspire-network.com;
#server_name wordpress.example.com;
ssl_certificate /etc/nginx/ssl/server.crt;
ssl_certificate_key /etc/nginx/ssl/server.key;
root /var/www/html/;
index index.php;set max upload size
client_max_body_size 2G;
fastcgi_buffers 64 4K;access_log /var/log/nginx/wordpress_https_access.log combined;
error_log /var/log/nginx/wordpress_https_error.log;location = /favicon.ico {
log_not_found off;
access_log off;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
try_files $uri $uri/ /index.php?$args ;
}location ~* .(htaccess|htpasswd) {
deny all;
location ~ .php(?:$|/) {
fastcgi_split_path_info ^(.+.php)(/.+)$;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_param PATH_INFO $fastcgi_path_info;
fastcgi_param HTTPS on;
fastcgi_pass php-handler-https;
fastcgi_read_timeout 60s;
set long EXPIRES header on static assets
location ~* .(?:jpg|jpeg|gif|bmp|ico|png|css|js|swf)$ {
expires 30d;
access_log off;
Here's the http.conf for wordpress (in the nginx directory):
upstream php-handler-http {
listen 80 default_server;
#server_name wordpress.example.com;root /var/www/html/;
fastcgi_buffers 64 4K;access_log /var/log/nginx/wordpress_http_access.log combined;
error_log /var/log/nginx/wordpress_http_error.log;location = /favicon.ico {
log_not_found off;
access_log off;
allow all;
log_not_found off;
access_log off;
}location / {
deny all;
fastcgi_pass php-handler-http;
expires 30d;
access_log off;
