I am getting this message (no certs found):
Cannot find a VirtualHost matching domain .net.
Linux Debian server 7.3
Hi @ranch,
What command did you run?
is this a TYPO "domain .net"?
Thanks for replying. I meant to put in the sequence I entered.
sudo ./certbot-auto --nginx
Then I tried:
sudo ./certbot-auto --nginx certonly
The domain name was auto replaced with ‘domain .net’ by the forum site. My correct DN was entered into the instruction line.
How did you tell Certbot your domain name?
root@me~# sudo ./certbot-auto --nginx certonly
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‘c’ to cancel):
I entered it at the above : in the format ‘me.net’
Do you have an nginx configuration file for that name? Can you post the configuration file and also the location where it’s saved?
Don’t see anything in there. I don’t remember having to do anything like that with another server I set up. Can you tell me what needs to be entered?
cat /etc/nginx.conf
user www-data;
worker_processes 4;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
Do you currently have a virtual host for that site that works in HTTP, or do you just have the domain name pointed at the server without any specific related server configuration yet?
http is already setup and working now.
Did you edit any file to make that happen? Perhaps in /etc/nginx/sites-available?
This is an issue with our nginx plugin - it won’t do a challenge unless you have a server_name set in your virtual host that matches the one that you specify on the command line.
We’re going to fix this: https://github.com/certbot/certbot/issues/5030
But for now you should just add a server_name directive that mentions the domain you want a cert for.
Where do I add a server_name directive and what form should it be in?
Figured that out:
listen 443 default_server;
# SSL configuration
root /var/www/html;
server_name me.net;
try_files $uri $uri/ =404;
I seem to have gotten further.
blank to select all options shown (Enter ‘c’ to cancel): 1
tls-sni-01 challenge for me.net
nginx: [emerg] a duplicate listen 0.0.0.0:443 in /etc/letsencrypt/le_tls_sni_01_cert_challenge.conf:1
nginx restart failed:
Got it!
SwartzCrCertbot had the answer. And I had the 443 line incorrectly delimitered also.
Thanks for the help and thanks for your efforts, schoen.
