My domain is: theorganicstore.com.ar
I ran this command: We are using an acme client in a PHP script that requests certificates for several domains. I'm using theorganicstore.com.ar as an example, but the issue happens with others domains too.
It produced this output: The response we're getting when trying to solve the challenges is:
"identifier":{
"type":"dns",
"value":"theorganicstore.com.ar"
"status":"invalid",
"expires":"2019-01-22T20:16:49Z",
"challenges":[
"type":"tls-sni-01",
"type":"dns-01",
"type":"http-01", // This is the challenge we're aiming to solve
"status":"invalid",
"error":{
"type":"urn:acme:error:connection",
"detail":"Fetching http://theorganicstore.com.ar/.well-known/acme-challenge/4YL3podIpvjMBxCt4b3rNunDpVyOopwWaCAZ_QBZN88: Timeout during connect (likely firewall problem)",
"status":400
"uri":"https://acme-v01.api.letsencrypt.org/acme/challenge/myCaqTZqqxR4GPQjkg3d4vN0GMx1lWPc5rpnx8c7Odk/11502104564",
"token":"4YL3podIpvjMBxCt4b3rNunDpVyOopwWaCAZ_QBZN88",
"validationRecord":[
"url":"http://theorganicstore.com.ar/.well-known/acme-challenge/4YL3podIpvjMBxCt4b3rNunDpVyOopwWaCAZ_QBZN88",
"hostname":"theorganicstore.com.ar",
"port":"80",
"addressesResolved":[
"52.200.197.31"
"addressUsed":"52.200.197.31"
"type":"tls-alpn-01",
"combinations":[
[2], [1], [3], [0]
My web server is: nginx/1.14.0, hosted on AWS.
The operating system my web server runs on is: Ubuntu 14.04.4 LTS
The important part of the output is this:
We're trying to understand why this happens. This is what we've observed during our research:
- Accessing http://theorganicstore.com.ar/.well-known/acme-challenge/4YL3podIpvjMBxCt4b3rNunDpVyOopwWaCAZ_QBZN88 works fine, and returns the expected answer.
- The DNS is properly configured. An "A" record pointing to 52.200.197.31, and no IPv6 record.
- The request never reaches our nginx logs (this is the weirdest) and we don't have anything between our DNSs and the nginx. Our servers are in AWS.
- The error is not permanent. After retrying once or twice, the certificate is issued without problems.
I would really appreciate some help to know more about the request made by LE, the response received, and why it fails randomly ![]()
Thanks in advance!
If anything like that is happening, might be on the AWS side. I’ll double check that in the AWS console. Thank you for your help!
