Help generating certificate for MikroTik RouterOS v6.38.5
Hi there!
I’m new to this forum and trying to get a certificate for MikroTik CloudCore Router, my intention is to redirect hotspot users to a secured page and I loved the concept of Let’s Encrypt so if any one help me to install a certificate on it would be great :slight_smile:
MikroTik RouterOS
Thank you.
I doubt RouterOS itself is capable of running a Let’s Encrypt client.
This blog shows how he/she did it: https://www.ollegustafsson.com/en/letsencrypt-routeros/
Here’s some more info from Mikrotik self: https://wiki.mikrotik.com/wiki/Manual:Create_Certificates
I’m sure you would be able to automate many of those things. The client used in the first link is acme.sh and has many options, such as a very large amount of DNS API plugins so you hopefully are able to automate the DNS challenge. If not, you might consider using the http challenge, which would require a specific file on a specific location on the exact hostname you want the cert for.
Successfully installed my cert!
Thanks!
hi @krishna
can you provide some insights as how you did it for other people
for example: what method did you use, any gotchas.
Screenshots would be great as well
I try to share with the class if possible :smiley:
Andrei
Hi @ahaw021,
By using super guide followed here https://www.ollegustafsson.com/en/letsencrypt-routeros/
Step-1 to Step-4 done on my CentOS.
At step-3 you’ll get the challenge to set it on your Domain DNS. I’ve added a TXT record for my domain after that issued Step-4 command.
Then I’ve got few files which is (.cer and .key, …).
I’ve downloaded them and uploaded to my RouterOS to work with.
thanks mate :D:D
good to know those instructions still work and can help other people :smiley:
I guess so :slight_smile:
Realise certificates from Let’s Encrypt are only valid fof 90 days, so every manual step would have to be repeated between 2 to 3 months from now.
the effort is less than 2 minutes
**upload 2xfiles **
import certs and keys
associate with web service
scriptable :
upload cert and key files using SCP or SFTP - python paramiko library
import cert - python netmiko library
import key - python netmiko library
verify cert has key associated - python
apply cert to ip service web-ssl python netmiko library
references:
http://www.paramiko.org/
will there be reference code? YES!
when? depending if i find this or F5 cert installs more interesting :smiley:
Andrei
