Help! Challege failed for domain oleum.net
oleum.net
sudo certbot certonly --webroot
Please enter in your domain name(s) (comma and/or space separated) (Enter ‘c’
to cancel): oleum.net
http-01 challenge for oleum.net
Input the webroot for oleum.net: (Enter ‘c’ to cancel): /var/www/oleum.net/
Waiting for verification…
Challenge failed for domain oleum.net
    Domain: oleum.net
    Type: connection
    Detail: Fetching
    http://oleum.net/.well-known/acme-challenge/9uvWJo0yrZRBhA9mNGnxLMSsFJDxW-keXHvTnF21wZQ:
    Connection refused
Note A record updated at 1and1 this afternoon, several hours ago. I can ssh in with key from a machine on a different fixed IP using sshusername@oleum.net so it looks like domain name is resolving to the ip address
apache2
ubuntu 20.0.4 LTS
hosted on fixed ip on network behind a linksys router
DMZ enabled and running ufw (ebabled but disabled when tested)
user elevated (sudo)
No
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 1.7.0
Also … https://letsdebug.net/oleum.net/267437
which is green!
oleum.net in my browser (firefox) fine
any ideas?
GeoLocation blocking.
curl -Iki http://oleum.net/
curl: (7) Failed to connect to oleum.net port 80: Connection refused
Well, looks like not listening to me.
Must be something else.
A few minutes earlier - I could fetch a result:
D:\temp>download http://oleum.net/.well-known/acme-challenge/9uvWJo0yrZRBhA9mNGnxLMSsFJDxW-keXHvTnF21wZQ -h
SystemDefault
Keep-Alive: timeout=5, max=100
Connection: Keep-Alive
Content-Length: 271
Date: Sun, 23 Aug 2020 18:36:26 GMT
Server: Apache/2.4.41 (Ubuntu)
Status: 404 NotFound
133,14 milliseconds
0,13 seconds
Now:
SystemDefault
ConnectFailure
3
Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 78.143.193.253:80
2324,57 milliseconds
2,32 seconds
Looks like a spam filter.
Yes something has definitely changed
I got a green on the lets debug page initially. I took firewall down for a while. Previously I’d only opened apache and ssh on a different port with key login only, now I get a bunch of red
lets go see if I have something set at ionos
brb
I had a spam filter set up on an email username@oleum.net in my ionos control panel. The server is not with ionos btw.
So are you running any kind of IPS or WebFilter (or such)?
Well I took down firewall and STARTED apache. Connected and…
Input the webroot for oleum.net: (Enter ‘c’ to cancel): /var/www/oleum.net/html
Subscribe to the EFF mailing list (email: oleum@oleum.net).
    /etc/letsencrypt/live/oleum.net/fullchain.pem
    /etc/letsencrypt/live/oleum.net/privkey.pem
    Your cert will expire on 2020-11-21. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot
    again. To non-interactively renew all of your certificates, run
    “certbot renew”
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
So looks solved?
I guess I better test it works now
Not if you have to bring down the firewall every time you need to renew your cert.
[well at least not in my book]
That's called a "work-around" - which merely sidesteps the problem.
firewall made no difference, it was because I had apache2 down, I think.
UFW is up now, get a green on the lets debug page.
I’ll be back in a few months if it wont renew :slight_smile:
Now how do I test if it works?
Much better now… but there are still some issue(s):
curl -Iki http://www.oleum.net/
HTTP/1.1 403 Forbidden
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
Content-Security-Policy: frame-ancestors 'self'
Content-Type: text/html; charset="utf-8"
Content-Length: 2931
Connection: Close
curl -Iki http://oleum.net/.well-known/acme-challenge/9uvWJo0yrZRBhA9mNGnxLMSsFJDxW-keXHvTnF21wZQ:
Content-Length: 2998
Connection: Close
If your Apache is down, a timeout is expected. There is no need to think about firewalls or something else.
Using webroot -> the webserver has to run.
@JuergenAuer runs a very nice public tool that can tell you much about your site.
You can also simulate a renewal with the --dry-run option.
So all is good I believe, except I’m not sure where these files have to go and what I need in my /etc/apache2/sites-available/my.site.conf file to enable them to be discovered.
Ive looked round a while , though someone might know and save me a lot of time/
TIA
I am not exactly sure of all of the idiosyncrasies of your configuration. Am I correct in assuming that you used certonly because you didn't want certbot to try to enable https and install your cert for you? If not, you could use certbot install.
have a look at a2ensite and a2dissite commands; they come with an Apache install and enable/disable sites.
The idea is that you can have multiple sites in conf/sites-available and enable them by symlinking to conf/sites-enabled.
I tend to use this quite often nowadays, even after thinking that I am a one-site-per-person type of guy :slight_smile:
The certificates+keys go in the letsencrypt-installed directories and your Apache conf (my-site.conf or whatever you call it) references them.
I also find it a bit annoying that letsencrypt needs http (for cert-renewal) in order to enable https (someone correct me if I am wrong) - I use a cronjob to remap 80 to my apache for cert-renewal and to another server during daytime.
Anyway, my ionos firewall has port 80 open all the time.
Thanks, I finally gave up before, restarting on a fresh install. I do have port 80 open right now anyway
