My domain is:tehcxweb.com
sudo /usr/local/bin/certbot --apache --agree-tos --redirect --hsts --staple-ocsp --email tav@tehcxweb.xyz -d mail.tehcxweb.xyz
Complete!
Creating virtual environment…
Installing Python packages…
Installation succeeded.
Error while running apachectl configtest.
AH00526: Syntax error on line 85 of /etc/httpd/conf.d/ssl.conf:
SSLCertificateFile: file ‘/etc/pki/tls/certs/localhost.crt’ does not exist or is empty
The apache plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError(“Error while running apachectl configtest.\n\nAH00526: Syntax error on line 85 of /etc/httpd/conf.d/ssl.conf:\nSSLCertificateFile: file ‘/etc/pki/tls/certs/localhost.crt’ does not exist or is empty\n”,)
[tav@mail ~]$ sudo systemctl reload httpd
Job for httpd.service failed because the control process exited with error code.
See “systemctl status httpd.service” and “journalctl -xe” for details.
My web server is (include version):Apache/2.4.37 (centos)
CentOS 8.1
My hosting provider, if applicable, is:reg.ru
no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):certbot 1.3.0
after errors apache also fails to start
Apache in default configuration
mail.tehcxweb.xyz.conf :
<VirtualHost *:80>
\ ServerName mail.tehcxweb.xyz
\ DocumentRoot /var/www/html/
</VirtualHost>
I’m just starting to learn CentOS help me figure it out
