You have successfully acquired certificates in the past week. You likely just need to install the last of those certificates, which should be stored on your NAS.
You can download the certificates, but if you've deleted their private keys then the certificates won't be of any use. From my estimates you should be able to generate another certificate now that the rate limit has lifted.
