My domain is: louisianaboilingpot.net and therareones.net
I ran this command: certbot certonly --expand -d louisianaboilingpot.net -d www.louisianaboilingpot.net -d therareones.net -d www.therareones.net
It produced this output: Successfully Created Certificates
My web server is (include version): Apache 2.4.35
The operating system my web server runs on is (include version): FreeBSD 11.2
My hosting provider, if applicable, is: Digital Ocean Droplet
Questions:
Recently I added the following domains to my certificate - therareones.net and www.therareones.net. They were added successfully with the command issued above, however, I noticed I have only one certificate (louisianaboilingpot.net). Eventually, I may not want to own this domain (louisianaboilingpot.net) and thus remove the certificate. What happens to the other domains attached to this certificate? Additionally, what would happen to the directory /usr/local/etc/letsencrypt/live/louisianaboilingpot.net/ if the certificate was deleted or removed?
Also, is it possible to create multiple LE Certificates so that they exist under separate directories?
Thanks in advance,
Scott
