My domain is: git.momoyon.org, www.git.momoyon.org
$certbot
Which interactively let me select the domains i want to add HTTPS for.
I selected 2 3 from:
1: momoyon.org
2: git.momoyon.org
3: www.git.momoyon.org
4: mail.momoyon.org
5: www.mail.momoyon.org
6: www.momoyon.org
Everything else has HTTPS already.
It produced this output: `Requesting a certificate for git.momoyon.org and www.git.momoyon.org
Domain: git.momoyon.org
Detail: 2401:c080:3000:36e1:5400:5ff:fe42:b43a: Invalid response from http://git.momoyon.org/.well-known/acme-challenge/BGenIO-njx4QbK-k9MZ0cS0dSmVXyPOGmAzFgM454ro: 404
Domain: www.git.momoyon.org
Detail: 2401:c080:3000:36e1:5400:5ff:fe42:b43a: Invalid response from http://www.git.momoyon.org/.well-known/acme-challenge/OHM5jC2qFgtZXN8wDX4vz47QC3u6DoRVtFazMHOIemg: 404
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.`
My web server is (include version): nginx version: nginx/1.22.1
The operating system my web server runs on is (include version): Linux momoyon 6.1.0-31-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.128-1 (2025-02-07) x86_64 GNU/Linux
My hosting provider, if applicable, is: https://vultr.com
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.1.0
Additional Info which i think could be helpful:
/var/log/letsencrypt/letsencrypt.log: 2025-05-11 09:31:20,787:DEBUG:certbot._internal.main:certbot version: 2.1.0202 - Pastebin.com
I use https://epik.com as my registrar for my doman.
Here are the CNAME (Subdomain) DNS Records for it:
NOTE: text inside is what i filled in.
- Host [www.git] .momoyon.org Points to [momoyon.org.] TTL[300]
- Host [git] .momoyon.org Points to [momoyon.org.] TTL[300]
- Host [www.mail] .momoyon.org Points to [momoyon.org.] TTL[300]
- Host [mail] .momoyon.org Points to [momoyon.org.] TTL[300]
