I am moving my web server to a different machine and I'm trying to get my cert update mechanism to work. The original machine was Ubuntu 20.4 and apache 2.4.52. It contained the apache server that connects to the outside world (with my web files) and also contains the certbot install. I have created deployment scripts that copy the updated certs to a number of different machines that also face the internet through very odd port numbers. (hence the extra domains)
The new installation has my web files on an apache red hat installation. It works fine now as a web server, but I have no way of getting cerbot to execute reliably there. So I have installed certbot on a Ubuntu 24.04 client machine and copied over all the LE files from the Ubuntu 20.04 server. I had to install apache in order to get the authentication to work happily. However, this version of apache does not face the internet.
illuminosi.com & others
sudo certbot certonly
--dry-run
--email tomf@illuminosi.com
--agree-tos --manual-public-ip-logging-ok
-d illuminosi.com,www.illuminosi.com,mail.illuminosi.com
-d unifi.illuminosi.com,unvr-1.illuminosi.com,untangle.illuminosi.com
--deploy-hook /etc/letsencrypt/renewal-hooks/deploy/my-deploy
Use of --manual-public-ip-logging-ok is deprecated.
An RSA certificate named illuminosi.com already exists. Do you want to update
its key type to ECDSA?
(U)pdate key type/(K)eep existing key type: u
Simulating renewal of an existing certificate for illuminosi.com and 5 more domains
Domain: illuminosi.com
Detail: 208.70.146.4: Invalid response from https://illuminosi.com/.well-known/acme-challenge/oGZFXwwWOUEir5Qp0MvdohP5b4zVCB6AjsCNQp9AwVg: 404
Domain: mail.illuminosi.com
Detail: 208.70.146.4: Invalid response from http://mail.illuminosi.com/.well-known/acme-challenge/XWl8d8oRim6_tnIX3IYqT4Mgm5W0JWm5SPkd4KXriv8: 404
Domain: unifi.illuminosi.com
Detail: 208.70.146.4: Invalid response from http://unifi.illuminosi.com/.well-known/acme-challenge/0K4DUIFNSO5E4XzszOknolPQJoT9IadUKJ4GQzbl4FE: 404
Domain: untangle.illuminosi.com
Detail: 208.70.146.4: Invalid response from http://untangle.illuminosi.com/.well-known/acme-challenge/RCCys6c1ivOnUIgE8_yfUdp8bJUvgdJycKFotI_UJX8: 404
Domain: unvr-1.illuminosi.com
Detail: 208.70.146.4: Invalid response from http://unvr-1.illuminosi.com/.well-known/acme-challenge/bYjOse1STbnvs7GsulncefjzZ5hGpNxavnDA8w1lAuU: 404
Domain: www.illuminosi.com
Detail: 208.70.146.4: Invalid response from https://www.illuminosi.com/.well-known/acme-challenge/PSPyqzlHCNYpvVNgXDNFLV24cYf8rcTNtCQYDIEVR7Q: 404
All done updating certificates!
Apache 2.4.55 r17
Linux RH-
Linux 5.13.x #1 SMP Fri Jul 5 00:11:59 CST 2024 x86_64 GNU/Linux
N/A
Yes
No.
or certbot-auto --version
if you're using Certbot):
cerbot 2.9.0
