californiaregionalcollaborative.org
Processing /etc/letsencrypt/renewal/californiaregionalcollaborative.org.conf
Simulating renewal of an existing certificate for californiaregionalcollaborative.org
Domain: californiaregionalcollaborative.org
Type: connection
Detail: 164.67.110.64: Fetching http://lsc-acme-cntrl.lsnet.ucla.edu/.well-known/acme-challenge/: Error getting validation data
apache 2.4
RHEL 8.6
ON PREMISES
YES
NO
1.30.0
I moved my certbot client from the web server where I created and deployed the SSL certificate to a different vm with no apache installed only certbot . From this vm I can run the command : certbot certificates and I get the correct result :
Found the following certs:
Certificate Name: californiaregionalcollaborative.org
Serial Number: 43f072e829eb58bb0ae77a390256504be2a
Key Type: RSA
Domains: californiaregionalcollaborative.org
Expiry Date: 2022-11-06 20:06:37+00:00 (VALID: 24 days)
Certificate Path: /etc/letsencrypt/live/californiaregionalcollaborative.org/fullchain.pem
Private Key Path: /etc/letsencrypt/live/californiaregionalcollaborative.org/privkey.pem
This VM where I run certbot renew is not the same for the DNS for californiaregionalcollaborative.org and this is why I'm getting the error mentioned before.
My question is : Can I run certbot client from a vm that does not have the DNS authority for the SSL certificate I'm trying to renew and is not a web server?
Googling around I found the article Automate cert renewal from different server which is similar to what I want to run my certbot client except that this vm does not have any web server do the redirect 301 doesn't make it sense to me.
What I want is a central certbot client server where I can perform renewal and deploy these certs to my web farm with an ansible script I already have in place. I'm already doing this using the sectigo ACME automation and I thought that the same concept would apply to this situation.
Thank you for all the help you can provide.
Marcello
